The instax mini Evo embodies a modern generation of analog, combining a classic look with more ways to create.
Show how you see the world
- Film Dial - Use the dial to switch film effects
- Lens Dial - Use the dial to switch lens effects
- Print Lever - Pull the lever to print
100 Different Expressions
Use the lens and film dials in combination to express your creativity in 100 different ways. Set up and capture your unique shots using the LCD screen. The mini Evo sparks ideas to unlock endless ways to express yourself!
App connectivity for simple use
Bluetooth connectivity
Print pictures from your Smartphone.
Send pictures from your Smartphone to the camera and print them out.
Film dial
Use the dial to switch film effects. -
Lens dial
Use the dial to switch lens effects. -
Print lever
Pull the lever to print. -
100 different expressions
Use the lens and film dials in combination to express your creativity in 100 different ways. Set up and capture your unique shots using the LCD screen. The mini Evo sparks ideas to unlock endless ways to express yourself! -
Print pictures from your smartphone
Send pictures from your smartphone to the camera and print them out. -
Printed picture taken by the camera can be save to your smartphone
Printed pictures can be saved as images with an instax frame on your smartphone. Share your favorite shot on social media! -
Use your smartphone as a remote control
Release the camera shutter using your smartphone as a remote control. -
High print quality
There are 100 different and fun ways to express yourself and get high quality instax prints.
- Fujifilm Instax mini Evo - digital camera
- Product Type
- Digital camera - compact with instant photo printer
- Optical Sensor Type
- CMOS
- Optical Sensor Size
- 1/5.0"
- ISO (Max)
- 1600
- Image Recording Format
- JPEG
- Interface
- Bluetooth
- Connectivity Features
- Remote control via mobile devices, wireless image printing
Exposure & White Balance
- Light Sensitivity
- ISO auto (100-1600)
- Exposure Metering
- Multi-segment
- Exposure Metering Zones
- 256
- Exposure Modes
- Automatic
- Special Effects
- Sepia, Mirror, Vivid, yellow, blue, red, fisheye, soft focus, monochrome, normal, Retro, Vignette, Blur, Canvas, Pale, Colour shift, Light leak, Double exposure, Half-frame
- White Balance
- Automatic, presets
- White Balance Presets
- Fine, incandescent, fluorescent, shade
- Max Shutter Speed
- 1/8000 sec
- Min Shutter Speed
- 1/4 sec
- Exposure Compensation
- ±2 EV range, in 1/3 EV steps
Lens System
- F/2.0
- Focal Length Equivalent to 35mm Camera
- 28mm
- Focus Adjustment
- Automatic
- Min Focus Distance
- 10 cm
Camera Flash
- Camera Flash
- Built-in flash
- Flash Modes
- Fill-in mode, auto mode, flash OFF mode
- AF illuminator
- Effective Flash Range
- 0.5 m - 1.5 m
Printer
- Printing Resolution
- 638 x 318 dpi
Additional Features
- Additional Features
- RGB primary colour filter, USB charging
Display
- 3" LCD display
- Display Format
- 460,000 pixels
- Display Form Factor
- Built-in
- Connector Type
- USB (power only) (5 pin Micro-USB Type B)
- Battery Type
- Lithium Ion - integrated
- Details
- Li-ion rechargeable battery (included)
Memory / Storage
- Memory Card Slot
- microSD card
- Supported Memory Cards
- microSD Card, microSDHC Card
- Image Storage
- JPEG 2560 x 1920
- 12.29 cm
- 3.6 cm
- 8.7 cm
- 285 g
- 40 °C
- 20 - 80% (non-condensing)
