Fujifilm FinePix XP60 - Digital camera - 3D - 16.4 Mpix - 5 x optical zoom - black
Quicklinx: 8NRKWS00 Mfr#: p10nc10020a
  • SDHC Memory Card
The indomitable FinePix XP60 features an internal 5x optical FUJINON zoom lens, which means that you can zoom right up to the action, even underwater. The technology continues to impress with the added application of intelligent digital zoom. The FinePix XP60 combines its 5x optical zoom with intelligent digital zoom which results in double the zoom range whilst offering optimum image processing to counteract the degradation that has traditionally occurred when digital zooms are used.
Characterized by high-speed processing, the CMOS sensor empowers continuous shooting at up to 10 frames/sec. or ultra-high-speed bursts at a maximum 60 frames/sec. A dedicated burst mode button" lets you instantly switch into continuous shooting mode, making it easy to capture exactly the moment or expression that you're shooting for.
  • Wide angle, 5x optical zoom and 10x intelligent digital zoom
  • Capture the action quickly and surely with continuous shooting toggle button
  • Full HD movie and movie recording button
    Thanks to the CMOS sensor, the FinePix XP60 can shoot 1920 x 1080-pixelFull HD video, at a maximum rate of 240 frames/second. A dedicated movie recording button makes it easy to switch to movie recording mode with a single touch.
  • High speed movie
    Sometimes things happen too fast for you to see them properly with your own eyes. The FinePix XP60 can freeze the action at up to an amazing 240fps! So you can see every single minute detail and watch things happening step by step in slow motion.
  • Movie edit
    The camera also incorporates a number of advanced movie-editing features, including "movie trimming" to cut un-wanted footage from movies, and "movie join" to join multiple separate clips into a single movie.
  • Noise cancellation
    Noise cancellation eliminates the sounds made by the zoom lens during recording.
  • Bright and clear LCD with an anti-reflective coating
    The bright, clear LCD monitor is treated with anti-reflective coating to ensure excellent visibility, even in bright sunlight. LCD monitor brightness is automatically adjusted in response to lighting conditions to maintain optimal visibility and prevent unnecessary battery drain.
  • 3D shooting with "individual shutter 3D"
    Two exposures of the same scene are saved in Multi-Picture Format (MPO) to create convincing images that appear to have been shot in real 3D. An overlapping guide on the LCD screen provides assistance for positioning the exposures, making it easy for anyone to create impressive 3D effects.
  • Pro low-light mode
    Ideal for shooting non-moving subjects in low light, this mode automatically takes a series of four high-sensitivity and low-noise exposures and then combines them into an image with less noise than the single exposures.
  • Dynamic Range (HDR)
    This mode uses Multi Frame technology to capture three consecutive photos shot at high speed-under-exposed, normal exposure, and over-exposed. The three images are then layered to an optimum balance of detail in shadow and highlights, eliminating "blackout" or "washout" and producing pleasing, natural gradations.
  • Natural light and with flash
    Can't decide whether it's best to use flash? Choose this mode, press the shutter and automatically capture the same scene twice: once with high sensitivity and natural light, and the second time with Intelligent Flash.
  • Face detection timer function
    The face detection self-timer automatically sets off after the number and position of faces in a scene are detected, snapping the photo at the right moment, with the faces in focus and properly exposed.
  • Share your images with built in social networking
    Don't wait until you get home to start choosing which pictures to upload to Facebook. Start the process in camera by tagging the pictures you want to share. The next time you connect to your home computer your images will upload automatically. The same goes for movie clips too, which can also be uploaded to YouTube.
Fujifilm FinePix XP60 - digital camera - Fujinon
Digital camera - compact
Lens Included
Fujinon
Memory Card Slot
SD card
Sensor Resolution
16.4 Megapixel
Max Video Resolution
1920 x 1080
Lens System
Zoom lens - 5x zoom - 5 - 25 mm - f/3.9-4.9
Focus Adjustment
Automatic
Min Focus Distance
60 cm
Digital Zoom
2x
Image Stabiliser
Optical (image sensor shift mechanism)
Camera Flash
Built-in flash
Display
LCD display - 2.7"
Supported Battery
1 x Fujifilm NP-45A Li-ion rechargeable battery (included)
HDMI, USB 2.0
10.41 cm x 2.63 cm x 6.65 cm
165 g
Lens Included
Fujinon
Enclosure Colour
Sensor Resolution
16.4 Megapixel
Optical Sensor Type
CMOS
Effective Sensor Resolution
16,400,000 pixels
Optical Sensor Size
1/2.3"
ISO (Max)
6400
Optical Zoom
5x
Digital Zoom
2x
Image Stabiliser
Built-in Optical Image Stabiliser
Face Detection
Print Standard
DPOF support, Exif Print support, PictBridge support
Auto Focus
TTL contrast detection
AE/AF Control
Subject-tracking AF
Face Detection
Face Detection Self-timer
Digital Video Format
H.264
Image Recording Format
JPEG, MPO
1920 x 1080
HDMI, USB 2.0
Exposure & White Balance
Light Sensitivity
ISO 100, ISO 800, ISO 400, ISO 200, ISO 1600, ISO 3200, ISO auto, ISO 6400 (8MP)
Exposure Metering
Multi-segment
Exposure Metering Zones
256
Exposure Modes
Programme, automatic
Shooting Programs
Landscape, portrait mode, night mode, text, party/indoor, 3D image, flower, Underwater, sports mode, sunset, beach, night (tripod), underwater macro, natural light, snow, natural light & with flash, pro low light, Dynamic Range (HDR), motion panorama360
Special Effects
Soft focus, miniature, partial colour, Toy camera, High Key, Pop Colour, Cross Screen
White Balance
Automatic, presets
White Balance Presets
Fine, incandescent, shade, fluorescent light (cool white), fluorescent light (warm white), Underwater, fluorescent light (daylight white)
Max Shutter Speed
1/2000 sec
Min Shutter Speed
4 sec
Exposure Compensation
±2 EV range, in 1/3 EV steps
Lens System
Fujinon zoom lens - 5x zoom - 5 - 25 mm - f/3.9-4.9
Focal Length Equivalent to 35mm Camera
28 - 140mm
Focus Adjustment
Automatic
Min Focus Distance
60 cm
Macro Focus Range
9-80cm
Zoom Adjustment
Motorised drive
Lens Construction
11 groups / 13 elements
Camera Flash
Camera Flash
Built-in flash
Flash Modes
Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
Red-Eye Reduction
Effective Flash Range
0.7 m - 3.1 m: ISO auto (wide lens) , 0.7 m - 2.7 m: ISO auto (tele lens) , 0.3 m - 0.8 m: ISO auto (macro lens)
Additional Features
Continuous Shooting Speed
10 frames per second for 10 frames, 5 frames per second for 10 frames, 3 frames per second for 10 frames, 60 frames per second for 70 frames (2MP)
Self-Timer Delay
10 sec, 2sec
Additional Features
RGB primary colour filter, digital image rotation, in-camera red-eye removal, cropping an image, resizing an image, Automatic Scene Recognition (SR Auto), in-camera film editing, Individual shutter 3D shooting, automatic display brightness adjustment, Motion Panorama 360, HDR image enhancement technology, high-speed recording, date stamp, silent shooting
Display
2.7" LCD display
Display Format
230,000 pixels
Display Form Factor
Built-in
Microphone
Microphone Operation Mode
Mono
Connector Type
USB 2.0 , HDMI output
Software
Software
Drivers & Utilities
Hand strap, AC power adaptor, USB cable
Protection
Waterproof, freezeproof, shockproof, dust-resistant
Underwater Use
Underwater Depth
Up to 6 m
Battery Type
Fujifilm NP-45A Lithium Ion - manufacturer-specific
Details
Battery Life Details
Photo shooting - 200 shots (AUTO mode)
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Image Storage
JPEG 4608 x 3456 , JPEG 4608 x 3072 , JPEG 4608 x 2592 , JPEG 3456 x 3456 , JPEG 3264 x 2448 , JPEG 3264 x 1836 , JPEG 2048 x 1536 , JPEG 1920 x 1080
Video Capture
H.264 - 1920 x 1080 , H.264 - 1280 x 720 - 60 fps , H.264 - 640 x 480 - 30 fps , H.264 - 640 x 480 - 80 fps , H.264 - 320 x 240 - 160 fps , H.264 - 320 x 120 - 240 fps
10.41 cm
2.63 cm
6.65 cm
165 g
-10 °C
10 - 80% (non-condensing)
