USB recording - record TV programmers directly from your TV to an external hard drive, connected to a USB port on your TV. More and more TVs have this feature enabled. Why not make full use of it? And when you do, why not use a uniquely designed external hard drive which looks stunning next to your TV The Mobile Drive Sq TV has it all. Looks and performance. For your convenience it also comes with a cradle with which you can fix the Mobile Drive Sq to the back of your TV, should you want to keep it out of sight.
Designed by acclaimed industrial designer Arman Emami from Germany, the Mobile Drive Sq TV features a unique organic design, like nothing you've ever seen before. Smooth lines and a square form factor. To make it less susceptible to scratches and fingerprints, the Mobile Drive Sq TV's enclosure cover is made from sandblasted stainless steel. In short - the Sq is guaranteed to turn some heads! The drive can of course also be used as a standard external hard drive. The Mobile Drive Sq TV boasts the USB 3.0 interface, ensuring ultra fast transfer speeds compared to standard USB 2.0. The drive is fully downwards compatible with older USB 2.0 ports, so you can use it on any computer and be ready for the future at the same time! The Mobile Drive Sq TV is powered by the USB port, no need for additional long cables or power adapters. If you're looking for an exclusive looking hard drive with matching performance and ultimate portability features, look no further - the Mobile Drive Sq TV is the drive to have!
USB recording
USB recording enables you to record digital TV programmers to an external storage device directly connected to your TV via USB. Your external HDD basically acts as a video recorder, and can replace your current HDD/DVD recorder. You can also use it to pause live TV. Most new TVs now offer USB recording functionality. The Mobile Drive Sq TV is the first external hard drive dedicated to USB recording. With the included cradle you can easily fix the drive to the back of your TV. -
It's all about design
There is nothing standard about the Mobile Drive Sq's design. Flowing lines, rounded edges, and a square form factor. This drive really stands out from the crowd! The uniqueness of the Mobile Drive Sq predominantly lies in its shape. Rather than your standard external hard drive box, this drive has an almost square form factor and features organic shapes with rounded edges. -
Stainless steel
To prevent the drive from scratches and fingerprints, the Mobile Drive Sq's enclosure cover is made out of stainless steel. The surface has been sandblasted to give it an exclusive look and feel. It will look stunning next to your notebook!
- Freecom Mobile Drive Sq TV - hard drive - 1 TB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 1 TB
- Form Factor
- 2.5"
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0) / internal: 5000 MBps
- Power Source
- USB bus
- Enclosure Colour
- Black, silver
- 12 cm x 12 cm x 1.3 cm
- 210 g
- Capacity
- 1 TB
- Form Factor
- 2.5"
- Interface
- USB 3.0
- 12 cm
- 12 cm
- 1.3 cm
- 210 g
Performance
- Interface Transfer Rate
- Drive Transfer Rate
- 5000 MBps (external)
Expansion & Connectivity
- 1 x USB 3.0
- Compatible Bay
- 2.5"
- Power Source
- USB bus
- Cables Included
- 1 x USB cable - external
- Enclosure Colour
- Black, silver
