Looking for the high possible capacity in the smallest possible size? Meet the smallest mobile drive in the world! The Mobile Drive XXS is the perfect solution for you.
Freecom's Mobile Drive XXS is the ideal mobile hard drive if you travel frequently. Or when you just need to have your files nearby at all times. Store them on your XXS and always have your business and personal files with you.
The Mobile Drive XXS is made out of rubber which not only provides a stylish look, but also gives the necessary grip to avoid dropping your hard drive.
Size matters
Looking for the high possible capacity in the smallest possible size? Meet the smallest mobile drive in the world! The Mobile Drive XXS is the perfect solution for you. -
Your important files always at hand
Freecom's Mobile Drive XXS is the ideal mobile hard drive if you travel frequently. Or when you just need to have your files nearby at all times. Store them on your XXS and always have your business and personal files with you. -
Get a grip
- Freecom Mobile Drive XXS 3.0 - hard drive - 2 TB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 2 TB
- Form Factor
- 2.5"
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Power Source
- USB bus
- Enclosure Colour
- Black
- 12 cm x 8 cm x 1.6 cm
- 185 g
- 2-year warranty
- Capacity
- 2 TB
- Form Factor
- 2.5"
- Interface
- USB 3.0
- 12 cm
- 8 cm
- 1.6 cm
- 185 g
Performance
- Interface Transfer Rate
Reliability
- MTBF
- 50,000 hours
Expansion & Connectivity
- 1 x USB 3.0
- Compatible Bay
- 2.5"
- Power Source
- USB bus
- OS Required
- Apple MacOS X 10.6 or later, Microsoft Windows Vista / XP / 7 / 8
- Cables Included
- 1 x USB cable - external
- Enclosure Colour
- Black
- Limited warranty - 2 years
- 10 °C
- 35 °C
