Fractal Design Silent Series R3 fans offer excellent value for money, with good performance and assured reliability. All Fractal Design Silent Series R3 fans are equipped with long-life rifle bearings and an easy-to-hide, sleek black cable. The Silent Series R3 delivers suitable options for replacing loud or damaged fans in both computers and many other electronic devices.
- Fractal Design Silent Series R3 - case fan
- Product Type
- Case fan
- Package Content
- 4 screws
- Black, white
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Rifle bearing
- Rotation Speed
- 1200 rpm
- Air Flow
- 46.5 cfm
- Noise Level
- 20.5 dBA
- Power Connector
- 3-pin plug
- Rated Voltage
- 12 V
- 12 cm x 12 cm x 2.5 cm
- 125 g
- Product Type
- Case fan
- Package Content
- 4 screws
- 12 cm
- 12 cm
- 2.5 cm
- 125 g
- Black, white
Heatsink & Fan
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Rifle bearing
- Rotation Speed
- 1200 rpm
- Air Flow
- 46.5 cfm
- Air Pressure
- 0.78 mm
- Noise Level
- 20.5 dBA
- Power Connector
- 3-pin plug
- Rated Voltage
- 12 V
- Start Voltage
- 6 V
- Rated Current
- 0.12 A
- Power Consumption
- 1 W
- Cable Length
- 35 cm
- MTBF
- 40,000 hour(s)
