Simple to install, silent operation, powerful performance and easy expandability define the Kelvin series. The silent high-performance ceramic pump is strong enough to support considerable expansion, should you decide to include GPU blocks and/or additional radiators in the same loop.
The Kelvin series water cooling systems are constructed from enthusiast class components. Both the CPU block and the radiator are made from pure copper, for maximum performance and an increased product life span with zero maintenance required.
All modern CPU sockets are supported by the versatile, easy-to-use mounting kit.
- Fractal Design Kelvin S24 - processor liquid cooling system
- Product Type
- Processor liquid cooling system
- Package Content
- Thermal paste, mounting hardware, PWM splitter cable
- Black
- Compatibility
- LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket, Socket FM2+
- Heatsink Material
- Copper
- Fans Qty
- Dual
- Fan Diameter
- 120 mm
- Rotation Speed
- 800-1700 rpm
- Air Flow
- 62.4 cfm
- Noise Level
- 26.9 dBA
- Rated Voltage
- 12 V
- Pulse-width modulation (PWM) support
- 2 kg
- G1/4" thread
- Product Type
- Package Content
- 2 kg
- Black
Heatsink & Fan
- Compatible With
- Heatsink Material
- Copper
- Heatsink Dimensions
- 69 mm x 69 mm x 40 mm
- Fans Qty
- 2
- Fan Diameter
- 120 mm
- Rotation Speed
- 800-1700 rpm
- Air Flow
- 62.4 cfm
- Air Pressure
- 2.33 mm
- Noise Level
- 26.9 dBA
- Rated Voltage
- 12 V
- Rated Current
- 0.18 A
- G1/4" thread
