Fractal Design Dynamic Series GP-12 (120mm) Computer Case Fan
Quicklinx: BBKVWS00 Mfr#: FD-FAN-DYN-GP12-WT
Fractal Design Dynamic GP-12 are true all-purpose fans, with good airflow in any usage scenario. Their customized design lends to a beautifully aesthetic fan to help keep your system cool, yet quiet.
Designed with leading technology techniques in mind, the Dynamic Series fans feature aerodynamic elements, similarly found in airplane wing designs, with significant noise-reducing elements, resulting in a fantastic price-performance ratio.
Fractal Design Dynamic GP-12 - case fan
Case fan
Package Content
4 screws
Black, white
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Hydraulic bearing
Rotation Speed
1200 rpm
Air Flow
52.3 cfm
Noise Level
19.4 dBA
Power Connector
3-pin plug
Rated Voltage
12 V
Trip wire technology, counter-balancing magnet, perpendicular blades
12 cm x 12 cm x 2.5 cm
119 g
Case fan
Package Content
4 screws
12 cm
12 cm
2.5 cm
119 g
Black, white
Heatsink & Fan
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Hydraulic bearing
Rotation Speed
1200 rpm
Air Flow
52.3 cfm
Air Pressure
0.88 mm
Noise Level
19.4 dBA
Power Connector
3-pin plug
Rated Voltage
12 V
Start Voltage
4 V
Rated Current
0.18 A
Power Consumption
1.44 W
Cable Length
50 cm
MTBF
40,000 hour(s)
