Fractal Design Dynamic GP-12 are true all-purpose fans, with good airflow in any usage scenario. Their customized design lends to a beautifully aesthetic fan to help keep your system cool, yet quiet.
Designed with leading technology techniques in mind, the Dynamic Series fans feature aerodynamic elements, similarly found in airplane wing designs, with significant noise-reducing elements, resulting in a fantastic price-performance ratio.
- Fractal Design Dynamic GP-12 - case fan
- Product Type
- Case fan
- Package Content
- 4 screws
- Black, white
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Hydraulic bearing
- Rotation Speed
- 1200 rpm
- Air Flow
- 52.3 cfm
- Noise Level
- 19.4 dBA
- Power Connector
- 3-pin plug
- Rated Voltage
- 12 V
- Trip wire technology, counter-balancing magnet, perpendicular blades
- 12 cm x 12 cm x 2.5 cm
- 119 g
- Product Type
- Case fan
- Package Content
- 4 screws
- 12 cm
- 12 cm
- 2.5 cm
- 119 g
- Black, white
Heatsink & Fan
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Hydraulic bearing
- Rotation Speed
- 1200 rpm
- Air Flow
- 52.3 cfm
- Air Pressure
- 0.88 mm
- Noise Level
- 19.4 dBA
- Power Connector
- 3-pin plug
- Rated Voltage
- 12 V
- Start Voltage
- 4 V
- Rated Current
- 0.18 A
- Power Consumption
- 1.44 W
- Cable Length
- 50 cm
- MTBF
- 40,000 hour(s)
