The Fractal Design Define R5 is the next evolution in the widely popular Define Series. Packed with intelligently designed enthusiast-oriented features delivering a silent case with powerful and expansive air and liquid cooling support, presented in a stunning Scandinavian inspired construction. The Define R5 case reaches the highest level of silent computing through strategically placed dense sound-absorbing material, ModuVent fan vent covers and finely tuned Dynamic Series fans.
The Define R5 was designed with configurability in mind, accommodating up to 8 hard drives and all modern graphics card. Should you wish to expand your system with water cooling components or more fans the layout can easily be configured to meet your demand.
- Fractal Design Define R5 - Window - tower - ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- Windowed Side Panel
- Black
- Built-in Devices
- Fan / power controller
- I/O Connectors
- 2 x USB 2.0 , 2 x USB 3.0 , 1 x headphones , 1 x microphone
- Supported Motherboards
- ATX, microATX, Mini-ITX
- System Cabinet Features
- Front dust filter, ModuVent, bottom dust filter, supports 120/140/240/280/360/420 mm radiator in top, supports 120/240 mm radiator in bottom, supports 120/140/240/280/360 mm radiator in front panel, supports 120/140 mm radiator in rear
- Power Device
- (ATX)
- 23.2 cm x 52.1 cm x 45.1 cm
- 10.3 kg
- Form Factor
- Tower
- Max Mainboard Size
- ATX
- Internal Bays Qty
- 10
- Front Accessible Bays Qty
- 2
- Built-in Devices
- Black
- Cooling System
- Front: 120/140 mm fan mount x 2 , Front: 140 mm fan x 1 / 1000 rpm , Rear: 140 mm fan x 1 / 1000 rpm / 1 x 120/140 mm fan supported , Top: 120/140 mm fan mount x 3 , Bottom: 120/140 mm fan mount x 2
- Video Card Max Length
- 440 mm
- Expansion Bays
- 2 (total) / 2 (free) x front accessible - 5.25" , 8 (total) / 8 (free) x internal - 2.5" / 3.5" shared , 2 (total) / 2 (free) x internal - 2.5"
- Expansion Slots
- 7
- Specification Compliance
- ATX
- 23.2 cm
- 52.1 cm
- 45.1 cm
- 10.3 kg
