Fractal Design Define R5 Computer Case (Black) with USB 3.0
Quicklinx: B34FWS00 Mfr#: FD-CA-DEF-R5-BK-W
The Fractal Design Define R5 is the next evolution in the widely popular Define Series. Packed with intelligently designed enthusiast-oriented features delivering a silent case with powerful and expansive air and liquid cooling support, presented in a stunning Scandinavian inspired construction. The Define R5 case reaches the highest level of silent computing through strategically placed dense sound-absorbing material, ModuVent fan vent covers and finely tuned Dynamic Series fans.
The Define R5 was designed with configurability in mind, accommodating up to 8 hard drives and all modern graphics card. Should you wish to expand your system with water cooling components or more fans the layout can easily be configured to meet your demand.
Fractal Design Define R5 - Window - tower - ATX
System cabinet
Tower
Built-in Devices
Fan / power controller
I/O Connectors
2 x USB 2.0 , 2 x USB 3.0 , 1 x headphones , 1 x microphone
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Windowed side panel, front dust filter, ModuVent, bottom dust filter, supports 120/140/240/280/360/420 mm radiator in top, supports 120/240 mm radiator in bottom, supports 120/140/240/280/360 mm radiator in front panel, supports 120/140 mm radiator in rear
Specification Compliance
ATX
23.2 cm x 52.1 cm x 45.1 cm
10.3 kg
Tower
Max Mainboard Size
ATX
ATX
Internal Bays Qty
10
Front Accessible Bays Qty
2
Built-in Devices
Cooling System
Front: 120/140 mm fan mount x 2 , Front: 140 mm fan x 1 / 1000 rpm , Rear: 140 mm fan x 1 / 1000 rpm / 1 x 120/140 mm fan supported , Top: 120/140 mm fan mount x 3 , Bottom: 120/140 mm fan mount x 2
Video Card Max Length
440 mm
Expansion Bays
2 (total) / 2 (free) x front accessible - 5.25" , 8 (total) / 8 (free) x internal - 2.5" / 3.5" shared , 2 (total) / 2 (free) x internal - 2.5"
Expansion Slots
7
23.2 cm
52.1 cm
45.1 cm
10.3 kg
