Product
Brand
Fractal Design Define R5 Arctic White Case
Quicklinx: 9ZDSWS00 Mfr#: FD-CA-DEF-R5-WT
Case Form Factor: Tower
Motherboard Form Factor: ATX
Colour: White, White
£80.83 ex VAT
£96.99 inc VAT
Define R5 - Definition of Silence
The Fractal Design Define R5 is the next evolution in the widely popular Define Series. Packed with intelligently designed enthusiast-oriented features delivering a silent case with powerful and expansive air and liquid cooling support, presented in a stunning Scandinavian inspired construction. The Define R5 case reaches the highest level of silent computing through strategically placed dense soundabsorbing material, ModuVentâ„¢ fan vent covers and finely tuned Dynamic Series fans.
The Define R5 was designed with configurability in mind, accommodating up to 8 hard drives and all modern graphics cards. Should you wish to expand your system with water cooling components or more fans the layout can easily be configured to meet your demand.
  • Optimally designed for silent computing with high density noise-reducing material throughout the case for maximum sound absorption, while not compromising on airflow and cooling capabilities.
  • Extensive water cooling support for a case of this size; housing radiators up to 420mm in the top and 360mm in the front.
  • Equipped with new tool-less ModuVentâ„¢ fan slot covers allowing the user to install more fans if desired or keep fan slots covered to maximize sound absorption.
  • Including two Fractal Design Dynamic GP14 140mm fans developed for superlative airflow while still maintaining low noise levels.
  • Maintaining a dust-free interior with the help of dust filters that cover front and bottom air intakes that are easy to access from the front on the case.
  • Newly configured front door with dual side mounting to better fit your work space.
  • Three-speed fan controller is strategically integrated in the front panel and supports up to 3 fans.
  • Highlighting 2 dedicated SSD mounts cleanly placed behind the motherboard tray that feature innovative new brackets delivering a tool-free installation and removal
  • The HDD cage system holds up to eight 3.5" or 2.5" drives and is more adaptable than ever, allowing the user to modify the case layout according to personal preference with more places to relocate the cages
  • The ODD cage can easily be removed to gain additional interior space; the area can be freed up to allow for increased airflow, to provide a new place for HDD cage mounting or to make more room for water cooling components.
  • Sturdy metal HDD trays provide excellent dampening features for the hard drives while providing better airflow through the cage with an updated, more open design
  • The new and innovative Quick Release System on the left side of the case
Fractal Design Define R5 - tower - ATX
System cabinet
Tower
White
I/O Connectors
2 x USB 2.0 , 2 x USB 3.0 , 1 x audio line-in , 1 x audio line-out
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Front panel door, ModuVent
23.2 cm x 52.1 cm x 45.1 cm
11.2 kg
Tower
Max Mainboard Size
ATX
Internal Bays Qty
10
Front Accessible Bays Qty
2
White
Cooling System
Front: 140 mm fan x 1 / 1000 rpm , Rear: 140 mm fan x 1 / 1000 rpm , Top: 140 mm fan mount x 3 , Bottom: 140 mm fan mount x 2 , Side: 140 mm fan mount x 1
CPU Cooler Max Height
180 mm
Video Card Max Length
310 mm
Expansion Bays
2 (total) / 2 (free) x front accessible - 5.25" , 8 (total) / 8 (free) x internal - 3.5" , 2 (total) / 2 (free) x internal - 2.5"
Expansion Slots
7
23.2 cm
52.1 cm
45.1 cm
11.2 kg
Resources
The following resources are available for the Fractal Design Define R5 Arctic White Case
Colour: White
Colour: White
Brand: Fractal Design
Price Range Ex VAT: 50 - 100
