Product
Brand
Fractal Design Define R4 Black Pearl Mid-Tower Case Side Window
Clearance!
Clearance
Last Few Remaining
Limited Time Offer
Quicklinx: 8K0YWS00 Mfr#: FD-CA-DEF-R4-BL-W
The Fractal Design Define R4 is the latest in the Define Series of computer cases offering minimalistic and stunning Scandinavian design fused with maximum sound reduction, configurability and functionality.
Now featuring the option to have your Define R4 case with a large fully transparent window allowing you to display your setup in style.
The acrylic window side panel features the same clean, Scandinavian design as the case itself, and has a completely flat outer surface without any plastic bezel or rivets.
Fractal Design Define R4 - Window - tower - ATX
System cabinet
Tower
Black Pearl
I/O Connectors
2 x USB 2.0 , 2 x USB 3.0 , 1 x headphones , 1 x microphone
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Noise reduction, windowed side panel, front panel door, rotational drive cage, fan speed controller, removable HDD rack, front dust filter, floor dust filter, cable management holes, ModuVent
No power supply
Specification Compliance
ATX
23.2 cm x 52.3 cm x 46.4 cm
12.3 kg
Tower
Max Mainboard Size
ATX
ATX
Internal Bays Qty
10
Front Accessible Bays Qty
2
Black Pearl
Cooling System
Front: 140 mm fan x 1 / 1000 rpm / hydraulic bearing , Front: 120/140 mm fan mount x 1 , Rear: 140 mm fan x 1 / 1000 rpm / hydraulic bearing , Top: 120/140 mm fan mount x 2 , Bottom: 120/140 mm fan mount x 1
Expansion Bays
2 (total) / 2 (free) x front accessible - 5.25" , 8 (total) / 8 (free) x internal - 3.5" , 2 (total) / 2 (free) x internal - 2.5"
Expansion Slots
8 x Expansion Slot
2 x USB 2.0 , 2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
Accessory box
No power supply
23.2 cm
52.3 cm
46.4 cm
12.3 kg
