FortiSwitch Secure Access switches deliver outstanding security, performance and manageability for threat conscious small to mid-sized businesses, distributed enterprises and branch offices. Tightly integrated into the FortiGate Network Security Platform, the FortiSwitch secure access switches can be managed directly from the familiar FortiGate interface. This single pane of glass management provides complete visibility and control of all users and devices on the network, regardless of how they connect.
When a device connects to a secure access switch Ethernet port, it is first identified, and then the user is authenticated. Once authenticated, access to the network is granted based on pre-defined security policy from the FortiGate, ensuring secure network access across the enterprise, without impacting the user experience.
Single management framework
Reduces complexity and decreases management cost with network security functions managed through a singleconsole. -
Single policy provisioning
The same security policy can apply to a user or device regardless of how or where they connect to the network. Enables access to certain network ports based on the role of a user within the organization, such as in shared conference rooms or engineering facilities. -
Centralized authentication
All users are authenticated against the same user database, regardless of whether they connect to the wired or wireless network, including temporary guest users. -
Role-based ports
- Fortinet FortiSwitch 548D - switch - 48 ports - Managed - rack-mountable
- Switch - 48 ports - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 48 x 10/100/1000 + 4 x 10 Gigabit SFP+ + 2 x 40 Gigabit QSFP+
- Performance
- Switching capacity: 336 Gbps , Forwarding performance: 512 Mpps , Latency: 2 µs
- Capacity
- Virtual interfaces (VLANs): 4000 , Maximum aggregation groups: 26
- MAC Address Table Size
- 96K entries
- Jumbo Frame Support
- Routing Protocol
- IGMPv2, IGMP, IGMPv3
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH, CLI
- Routing, auto-negotiation, VLAN support, IGMP snooping, Syslog support, port mirroring, SNTP support, sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Jumbo Frames support, DHCP relay, Link Aggregation Control Protocol (LACP), DHCP client, Management Information Base (MIB), static routing, tagged VLAN, 4MB packet buffer, Storm Control
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ab (LLDP)
- Power
- AC 120/230 V (50/60 Hz)
- 44 cm x 31 cm x 4.4 cm
- 6.4 kg
- Limited lifetime warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- Performance
- Capacity
- 96K entries
- Routing Protocol
- Authentication Method
- Secure Shell (SSH), RADIUS, TACACS+
- RAM
- 2 GB
- Flash Memory
- 128 MB
- 48 x 1000Base-T RJ-45 , 4 x 10Gbit LAN SFP+ , 2 x 40Gbit LAN QSFP+ , 1 x management (Gigabit LAN) RJ-45 , 1 x console RJ-45
- Power Device
- Internal power supply
- Voltage Required
- 77 Watt
- MTBF
- 10 years
- UL, VCCI, BSMI, CB, FCC, RoHS, RCM
- 44 cm
- 31 cm
- 4.4 cm
- 6.4 kg
- Limited warranty - lifetime
- 0 °C
- 45 °C
- 5 - 95% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
