The FortiSwitch-5203B board is an Advanced Telecommunications Computing Architecture (ATCA) compliant hub/switch board. When operating in content cluster mode, the FortiSwitch-5203B board is session aware and can be configured with firewall policies and other FortiGate configuration options. The FortiSwitch-5203B board itself performs firewalling, stateful inspection, VPN routing and other FortiGate functions. The FortiSwitch-5203B board load balances sessions to the worker boards using weighted load balancing.
You also connect the FortiSwitch-5203B board to your 10-gigabit network using the F1 to F8 front panel SFP+ connectors. The front panel also includes an Ethernet management interface, an RJ-45 console port for connecting to the FortiOS CLI and a USB port. The USB port can be used with any USB key for backing up and restoring configuration files.
- Fortinet FortiSwitch 5203B - switch - plug-in module
- Switch
- Enclosure Type
- Plug-in module
- Subtype
- 10 Gigabit Ethernet
- Ports
- 8 x 10 Gigabit SFP+
- Performance
- Switching throughput: 300 Gbps
- Remote Management Protocol
- CLI
- 28.8 cm x 35.1 cm x 3.1 cm
- 3.2 kg
- Switch
- Enclosure Type
- Plug-in module
- Subtype
- Ports
- Performance
- CLI
- 8 x 10Gb Ethernet - SFP+ , 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 management , 1 x console RJ-45 management , 2 x 10Gb Ethernet - SFP+
- 210 Watt
- Included Accessories
- 2 SR SFP+ transceivers
- UL, VCCI, C-Tick, cUL, CB, FCC Part 15 A
- 28.8 cm
- 35.1 cm
- 3.1 cm
- 3.2 kg
- 0 °C
- 40 °C
- 5 - 90% (non-condensing)
- Min Storage Temperature
- -35 °C
- Max Storage Temperature
- 70 °C
