Product
Fortinet FortiSwitch 5203B Switch
Quicklinx: CJN9WS00 Mfr#: FS-5203B
£39,055.18 ex VAT
£46,866.21 inc VAT
The FortiSwitch-5203B board is an Advanced Telecommunications Computing Architecture (ATCA) compliant hub/switch board. When operating in content cluster mode, the FortiSwitch-5203B board is session aware and can be configured with firewall policies and other FortiGate configuration options. The FortiSwitch-5203B board itself performs firewalling, stateful inspection, VPN routing and other FortiGate functions. The FortiSwitch-5203B board load balances sessions to the worker boards using weighted load balancing.
You also connect the FortiSwitch-5203B board to your 10-gigabit network using the F1 to F8 front panel SFP+ connectors. The front panel also includes an Ethernet management interface, an RJ-45 console port for connecting to the FortiOS CLI and a USB port. The USB port can be used with any USB key for backing up and restoring configuration files.
Fortinet FortiSwitch 5203B - switch - plug-in module
Switch
Enclosure Type
Plug-in module
Subtype
10 Gigabit Ethernet
Ports
8 x 10 Gigabit SFP+
Performance
Switching throughput: 300 Gbps
Remote Management Protocol
CLI
28.8 cm x 35.1 cm x 3.1 cm
3.2 kg
Switch
Enclosure Type
Plug-in module
Subtype
10 Gigabit Ethernet
Ports
8 x 10 Gigabit SFP+
Performance
CLI
8 x 10Gb Ethernet - SFP+ , 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 management , 1 x console RJ-45 management , 2 x 10Gb Ethernet - SFP+
210 Watt
2 SR SFP+ transceivers
UL, VCCI, C-Tick, cUL, CB, FCC Part 15 A
28.8 cm
35.1 cm
3.1 cm
3.2 kg
5 - 90% (non-condensing)
Min Storage Temperature
-35 °C
Max Storage Temperature
70 °C
Type: 10 Gigabit Ethernet
Brand: Fortinet
Price Range Ex VAT: 1500+
