Product
Fortinet FortiSwitch 248D Switch
Quicklinx: CJNQWS00 Mfr#: FS-248D
Type: Gigabit Ethernet
Ports: 48
Managed: Yes
POE: No
£763.89 ex VAT
£916.66 inc VAT
FortiSwitch Secure Access switches deliver outstanding security, performance and manageability for threat conscious small to mid-sized businesses, distributed enterprises and branch offices. Tightly integrated into the FortiGate Network Security Platform, the FortiSwitch Secure Access switches can be managed directly from the familiar FortiGate interface. This single pane of glass management provides complete visibility and control of all users and devices on the network, regardless of how they connect. When a device connects to a Secure Access Switch Ethernet port, it is first identified, and then the user is authenticated. Once authenticated, access to the network is granted based on pre-defined security policy from the FortiGate, ensuring secure network access across the enterprise, without impacting the user experience.
  • Single management framework
    Reduces complexity and decreases management cost with network security functions managed through a single console.
  • Single policy provisioning
    The same security policy can apply to a user or device regardless of how or where they connect to the network.
  • Centralized authentication
    All users are authenticated against the same user database, regardless of whether they connect to the wired or wireless network, including temporary guest users.
  • Role-based ports
    Enables access to certain network ports based on the role of a user within the organization, such as in shared conference rooms or engineering facilities.
Fortinet FortiSwitch 248D - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 + 4 x Gigabit SFP
Performance
Switching throughput: 104 Gbps , Forwarding performance: 155 Mpps , Latency: 1 µs
Virtual interfaces (VLANs): 4000 , Maximum aggregation groups: 26
MAC Address Table Size
16K entries
Jumbo Frame Support
Routing Protocol
OSPF, BGP
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH, CLI
Flow control, DHCP support, VLAN support, port mirroring, SNTP support, sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Jumbo Frames support, LLDP support, Link Aggregation Control Protocol (LACP), Management Information Base (MIB), tagged VLAN, 1.5MB packet buffer
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.1AX
44 cm x 24.6 cm x 4.4 cm
3.54 kg
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
Routing Protocol
OSPF, BGP
Authentication Method
RADIUS
RAM
512 MB
Flash Memory
128 MB
Status Indicators
Power, link/activity
48 x 1000Base-T RJ-45 , 4 x Gigabit LAN SFP , 1 x console RJ-45 , 1 x management (Gigabit LAN) RJ-45
Internal power supply
38.66 Watt
MTBF
10 years
UL, VCCI, C-Tick, cUL, CB, FCC Part 15 A, RoHS2
44 cm
24.6 cm
4.4 cm
3.54 kg
Limited warranty - lifetime
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Ports: 48
Managed: Yes
POE: No
Brand: Fortinet
Price Range Ex VAT: 750 - 1000
