FortiSwitch secure access switch delivers outstanding security, performance and manageability for threat-conscious small to mid-sized businesses, distributed enterprises and branch offices. Tightly integrated into the FortiGate Network Security Platform, the FortiSwitch secure access switch can be managed directly from the familiar FortiGate interface. This single-pane-of-glass management provides complete visibility and control of all users and devices on the network, regardless of how they connect. When a device connects to a secure access switch Ethernet port, it is first identified, and then the user is authenticated. Once authenticated, access to the network is granted based on pre-defined security policy from the FortiGate, ensuring secure network access across the enterprise, without impacting the user experience.
Securely managed switch for wire closet installation
The FortiSwitch is ideal for the advanced applications, where increased productivity can be achieved through faster network access speeds via dedicated Gigabit Ethernet ports. With a compact 1RU form factor, this switch is ideally suited for high-density enterprise or classroom wire closet installations, delivering a truly secure network access platform for wired Ethernet devices. -
Simple network deployment and compliance
The Power over Ethernet (PoE) capability enables simple installation of wireless Access Points and IP phones in the network, with power and data being delivered over the same network cable. There is no need to contract electricians to install power for your PoE capable devices anymore, reducing your overall network TCO. -
FortiLink mode
The FortiSwitch secure access switch integrates directly into the FortiGate Connected UTM, with switch administration and access port security managed from the familiar FortiGate interface. Regardless of how users and devices connect to the network, you have complete visibility and control over your network security and access through this single pane of glass, perfectly suited to threat-conscious organizations of any size. -
Standalone mode
Virtualization and cloud computing have created dense high-bandwidth Ethernet networking requirements in the data center, pushing the limits of existing data center switching. FortiSwitch Data Center switch meets these challenges by providing a high-performance 10GE or 40GE capable switching platform, with a low total cost of ownership. Ideal for top of rack server or firewall aggregation applications, as well as enterprise network core or distribution deployments, this switch is purpose-built to meet the needs of today's bandwidth intensive environments.
- Fortinet FortiSwitch 248D-POE - switch - 48 ports - Managed - rack-mountable
- Switch - 48 ports - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 48 x 10/100/1000 (PoE+) + 2 x Gigabit SFP
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 370 W
- Performance
- Switching throughput: 104 Gbps , Forwarding performance: 155 Mpps , Latency: 1 µs
- Capacity
- Virtual interfaces (VLANs): 4000 , Maximum aggregation groups: 26
- MAC Address Table Size
- 16K entries
- Jumbo Frame Support
- Routing Protocol
- OSPF, BGP
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH, CLI
- Flow control, power over Ethernet (PoE), port mirroring, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Jumbo Frames support, LLDP support, Link Aggregation Control Protocol (LACP), Management Information Base (MIB), tagged VLAN, 1.5MB packet buffer
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP)
- Power
- AC 120/230 V (50/60 Hz)
- 44 cm x 42.9 cm x 4.4 cm
- 7.01 kg
- Limited lifetime warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 370 W
- Performance
- Capacity
- 16K entries
- Routing Protocol
- OSPF, BGP
- Authentication Method
- RADIUS
- RAM
- 512 MB
- Flash Memory
- 128 MB
- Status Indicators
- Power, PoE, link/activity
- 48 x 1000Base-T RJ-45 PoE+ , 2 x Gigabit LAN SFP , 1 x console RJ-45 , 1 x management (Gigabit LAN) RJ-45
- Power Device
- Internal power supply
- Voltage Required
- 476 Watt
- MTBF
- 10 years
- UL, VCCI, C-Tick, cUL, CB, RoHS, FCC Part 15 A
- 44 cm
- 42.9 cm
- 4.4 cm
- 7.01 kg
- Limited warranty - lifetime
- 0 °C
- 50 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
