Product
Fortinet FortiSwitch 1024D Switch
Quicklinx: CJR7WS00 Mfr#: FS-1024D
Type: 10 Gigabit Ethernet
Ports: 24
Managed: Yes
£7,330.14 ex VAT
£8,796.16 inc VAT
FortiSwitch Data Center switches deliver outstanding throughput, resiliency and scalability for organizations with high performance data center network requirements. They are ideal for Top of Rack server or firewall aggregation applications, as well as enterprise network core or edge deployments, where high performance 10 GE and 40 GE is required. Purpose-built to meet needs of today's bandwidth intensive data centers and enterprise networks, FortiSwitch Data Center Switches deliver high-performance with a low Total Cost of Ownership.
The FortiSwitch-1024D switch comes in a 1 RU form factor, equipped with dual hot swappable power supplies to maximize network uptime. With 10 GE access ports and a high-throughput backplane, the FortiSwitch Data Center Switches satisfy the Top of Rack server or firewall aggregation performance requirements of today's virtualization centric data centers.
Advanced Link Aggregation with 802.11ad and Link Aggregation Control Protocol provide increased uplink, server aggregation, or firewall aggregation throughput. Other advanced switch capabilities, such as large MAC address tables, jumbo frame support and port security, is standard features.
Fortinet FortiSwitch 1024D - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
24 x 1 Gigabit / 10 Gigabit SFP+
Performance
Switching capacity: 320 Gbps
Virtual interfaces (VLANs): 4000 , Maximum aggregation groups: 24
MAC Address Table Size
128K entries
Jumbo Frame Support
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, SSH, CLI
Flow control, DHCP support, VLAN support, port mirroring, SNTP support, sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Link Aggregation Control Protocol (LACP), Management Information Base (MIB), tagged VLAN
IEEE 802.3, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1AX, IEEE 802.11ad
Power Redundancy
43.85 cm x 46 cm x 4.35 cm
8 kg
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
Performance
128K entries
Jumbo Frame Support
Authentication Method
Secure Shell (SSH), RADIUS
24 x SFP+ , 1 x 1000Base-T RJ-45 management , 1 x console RJ-45 management
Installed Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
Power Provided
460 Watt
140 Watt
43.85 cm
46 cm
4.35 cm
8 kg
10 - 90% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Ports: 24
Managed: Yes
Brand: Fortinet
Price Range Ex VAT: 1500+
