Tilt it, swivel it, even hang it upside down! Flexsons bespoke bracket for the SONOS PLAY: 1 allows you to wall mount your speaker in the ideal place to sound - and look - great. This improved design gives you yet more flexibility and functionality. This Flexson mount has a unique tilting mechanism, as well as the ability to swivel left or right, so you can perfectly angle your sound. The bracket also allows you to hang the PLAY: 1 upside down? So you can access its on-speaker controls even when it is mounted high up. You can even mount your speaker on the ceiling! The Flexson wall mount for SONOS PLAY: 1 is precision engineered to perfectly match the size and style of the SONOS speaker. It also allows for neat cable routing, easy fitting and flexible placement. Free up your surfaces and mount your music today!
- Flexson FLXP1WB1011 mounting kit - for speaker(s) - white
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Wall mount bracket
- 3.5 cm x 6.2 cm x 12.7 cm
- Adjustments
- Tilt
- 200 g
- Recommended Use
- Speaker(s)
- White
- Designed For
- Sonos PLAY:1
- 3.5 cm
- 6.2 cm
- 12.7 cm
- 200 g
- White
AV Furniture
- Mounting kit
- Recommended Use
- Speaker(s)
- Placing / Mounting
- Wall-mountable
- Adjustments
- Tilt
- Swivel adjustment
- Designed For
- Sonos PLAY:1
