Product
Brand
Flexson Wall Mount for SONOS PLAY:1 - Black (Single)
Quicklinx: CB3GWS00 Mfr#: P1WB1021
Type: Wall mount
More than 50 in stock
£22.21 ex VAT
£26.65 inc VAT
Standard delivery Delivered within 3-5 working days
The Flexson FLXP1WB1021 wall bracket is the perfect choice for your Sonos Play 1 speaker. The Tilt and Swivel function allows you to set the bracket to your perfect position on either the wall or ceiling. With easy cable routing and and simple fitting this is the obvious choice for your PLAY 1 speaker.
Flexson FLXP1WB1021 - wall mount
Wall mount
3.5 cm x 6.2 cm x 12.7 cm
200 g
Recommended Use
Speaker(s)
Sonos PLAY:1
3.5 cm
6.2 cm
12.7 cm
200 g
AV Furniture
Wall mount
Mounting Components
Wall mount bracket
Recommended Use
Speaker(s)
Adjustments
Tilt
Swivel adjustment
Sonos PLAY:1
Type: Wall mount
Brand: Flexson
Price Range Ex VAT: 0 - 50
