Flexson TV Stand for SONOS PLAYBAR The SONOS PLAYBAR is the perfect way to add quality Home Cinema to your TV, but what if there isn't much space where your TV is located? Place it in front and it could be unstable sitting over the TV's foot. FLEXSON have the answer, a stylish steel stand. Sit your TV on top, slide the PLAYBAR underneath and you have a discreet practical solution. Designed and made in the UK from 2mm steel for a strong rigid support the FLEXSON TV Stand complements the styling and finish of the SONOS PLAYBAR. The Flexson TV Stand for PLAYBAR essentially transforms the SONOS soundbar into a soundbase for a flatscreen TV.
- Flexson stand - for flat panel / sound bar - black metallic
- Product Type
- Stand
- 90 cm x 30 cm x 8.5 cm
- 8.7 kg
- Recommended Use
- Flat panel / sound bar
- Max Load Weight
- 50 kg
- Material
- Steel
- Black metallic
- Designed For
- Sonos PLAYBAR
- 90 cm
- 30 cm
- 8.5 cm
- 8.7 kg
- Material
- Steel
- Black metallic
AV Furniture
- Stand
- Recommended Use
- Max Load Weight
- 50 kg
- Designed For
- Sonos PLAYBAR
