Flexson TV Stand for SONOS PLAYBAR - Black (Single)
Quicklinx: CB3MWS00 Mfr#: PBST1021
Type: Stand
More than 50 in stock
£88.88 ex VAT
£106.65 inc VAT
Flexson TV Stand for SONOS PLAYBAR The SONOS PLAYBAR is the perfect way to add quality Home Cinema to your TV, but what if there isn't much space where your TV is located? Place it in front and it could be unstable sitting over the TV's foot. FLEXSON have the answer, a stylish steel stand. Sit your TV on top, slide the PLAYBAR underneath and you have a discreet practical solution. Designed and made in the UK from 2mm steel for a strong rigid support the FLEXSON TV Stand complements the styling and finish of the SONOS PLAYBAR. The Flexson TV Stand for PLAYBAR essentially transforms the SONOS soundbar into a soundbase for a flatscreen TV.
Flexson - stand
Stand
90 cm x 30 cm x 8.5 cm
8.7 kg
Recommended Use
LCD / plasma panel / sound bar
Max Load Weight
50 kg
Material
Steel
Black metallic
Sonos PLAYBAR
90 cm
30 cm
8.5 cm
8.7 kg
Material
Steel
Black metallic
AV Furniture
Stand
Recommended Use
Max Load Weight
50 kg
Sonos PLAYBAR
Type: Stand
Brand: Flexson
Price Range Ex VAT: 50 - 100
