Flexson floorstands put your speakers at the ideal listening height. Whether you're streaming music to a single speaker, or using a pair of speakers in stereo, TV and more, your system will look - and sound great. The Flexson floorstand for PLAY:1 is a sturdy, metal design - with a stable base that can slip under sofas or chairs if needed. This edition has enhanced cable routing, with a cable channel at the rear of the upright column making it easier to neatly hide away the speaker's power cable.
- Flexson FLXP1FS1011 stand - for speaker(s) - white
- Product Type
- Stand - floor-standing
- 26.2 cm x 18.7 cm x 80.8 cm
- 3.7 kg
- Recommended Use
- Speaker(s)
- Material
- Metal
- White
- 1-year warranty
- Designed For
- Sonos PLAY:1
- 26.2 cm
- 18.7 cm
- 80.8 cm
- 3.7 kg
- Material
- Metal
- White
AV Furniture
- Stand
- Recommended Use
- Speaker(s)
- Placing / Mounting
- Floor-standing
- Cable Management
- Integrated cable management
- Limited warranty - parts and labour - 1 year
- Designed For
- Sonos PLAY:1
