Flexson Cantilever Mount for SONOS PLAYBAR + TV is a premium design that can hold both flatscreen TVs (37-55in) and the PLAYBAR itself, allowing both units to rotate to face the viewer. The Flexson Screen Mount fixes to your existing bracket, allowing you to slip in the SONOS PLAYBAR again, ensuring your sound moves in line with the screen. It suits all 37-55in flatscreens (all VESA mounts to 600 x 400mm).
- Vertical and horizontal adjustment to align screen and PLAYBAR.
- PLAYBAR appears as part of the TV and rotates in line with it.
- Rotates up to 180° with 40" screen.
- Fits screens 37" - 55" (all VESA mounts to 600 x 400mm ).
- Maximum TV 40 kgs.
- PLAYBAR can even be adjusted so that it lines up with the bottom.
- Flexson Cantilever bracket
- Product Type
- Bracket - wall-mountable
- 85 cm x 7.6 cm x 72.5 cm
- Rotation
- 180°
- Adjustments
- Horizontal
- 12.5 kg
- Recommended Display Size
- 37"-55"
- VESA Mounting Interface
- Up to 600 x 400 mm
- Max Load Weight
- 40 kg
- 85 cm
- 7.6 cm
- 72.5 cm
- 12.5 kg
AV Furniture
- Bracket
- Placing / Mounting
- Wall-mountable
- 37"-55"
- Rotation
- 180°
- Adjustments
- Horizontal
- Max Load Weight
- 40 kg
