Handcrafted with high-quality leather and other materials, this premium band creates a cool, casual look for your Fitbit Versa.
Works with all watches in the Versa family.
Size Guide
Small - Fits wrist 140 mm - 180 mm in circumference.
Materials
This leather band is made of premium leather and includes an aluminium buckle. Horween leather is a high-quality leather handcrafted and tanned in Chicago through traditional tanning techniques. Because this bands is made from natural materials, it will mould to your wrist and develop an aged patina finish over time.
Water Resistance
This leather band is not sweat or water-resistant. We recommend limited to no contact with moisture to reduce discolouration/damage to the band.
Care
This leather band is not intended for high intensity workouts. If the band gets wet or dirty we recommend using a non-abrasive, lint-free cloth. If needed, you can lightly dampen the cloth with water and let the band air dry.
Due to the natural characteristics of genuine leather, each piece will have a distinct variation in colour and texture. To maintain the life of your leather band, limit direct exposure to sunlight and moisture, which may cause fading over time. For light-coloured leather accessory bands, minimise direct contact with dark-coloured clothing, as colour transfer may occur. Learn more.
- Fitbit - band for smart watch
- Product Type
- Band
- Intended For
- Smart watch
- Band Size
- Small
- Product Material
- Horween leather
- Midnight blue
- 1-year warranty
- Designed For
- Fitbit Versa
- Product Type
- Band
- Intended For
- Smart watch
- Band Size
- Small
- Band Clasp Type
- Buckle
- Product Material
- Horween leather
- Midnight blue
- 1-year warranty
- Designed For
- Fitbit Versa
