Fitbit Flyer Wireless Fitness Headphones - Nightfall Blue
Quicklinx: DJYWWS00 Mfr#: FB601BU-EU
Colours:
Hear what moves you with powerful audio, a comfortable fit and a durable design that you can count on.
Wireless headphones made for workouts
Sweatproof, small and seriously durable, Flyer gives you freedom and confidence to take on your toughest workouts.
Sweatproof & Durable
With a durable design, integrated buttons and hydrophobic nano coating that’s rain, splash and sweatproof, Flyer was made to withstand even your toughest workouts.
Music & Call Controls
The 3-button control box lets you easily adjust the sound of your music and pause or change songs.
Go hands-free by using the 3-button control box to answer and end calls while you’re on a walk or working out.
Dual Microphone
With a dual microphone that suppresses external noise like wind, you’ll get high-quality calls in any environment.
Wear it anywhere, with anything.
Unique, low-profile and lightweight, these headphones are small and versatile enough to wear all day, during high-intensity exercise and even with glasses or helmets.
Talk to Siri & more
Flyer is compatible with Siri, Cortana & Google Assistant, so you can use simple voice commands to "Call Dad" & more.
Customise your fit for comfort and security
With interchangeable ear tips, wings and fins, you can create the optimal headphones for comfort, security and sound quality.
Stay motivated with high quality sound
Precision engineered for crisp audio, powerful bass and dynamic range, Flyer delivers sound that’s optimised for workouts and throughout the day.
Superior components. Superior wireless sound.
Precision engineered with high-quality components and an AAC Wireless Codec, Flyer delivers the premium sound you want – all without the wires.
Choose different settings for different songs.
Some songs just need a boost to bring them to life. Flyer lets you choose from two dynamic sound settings with the push of a button.
Signature:
Classic, crisp sound that’s perfect for your commute, your workday, your workouts and more.
Power Boost:
Amplify your bass, EQ and stereo feel with a setting enhanced by Waves technologies
Power Boost: built with the music industry’s best
From hit records and major motion pictures to popular video games and iconic concerts, the cutting-edge sound technologies from Waves have been used in every aspect of audio production.
Now, for the first time ever, they’re also used in headphones.
Only hear what matters.
With a solid in-ear seal and high-quality audio system, Flyer uses Passive Noise Isolation to reduce the distraction of outside noises to give you a cleaner sound.
An experience more effortless than ever
From six hours of play time to seamless connections with your favourite devices, the essential features make your experience better.
A battery that keeps up with you.
With up to six hours of playtime, Flyer has the battery life that you need to boost every workout and make the most of your day.
Find motivation fast.
Now you can say yes to last minute workouts and know that you’ve got the music to do it, because a quick charge of 15 minutes gives you a full hour of playtime.
Seamlessly swap from one device to another.
Flyer connects to two Bluetooth devices at once, so you can quickly swap from listening to music on your laptop to answering a call on your smartphone.
Plus, it remembers up to eight devices, so you don’t have to deal with the hassle of re-pairing.
Audio cues keep you in the know.
Flyer makes listening easier by giving you audio prompts for battery life, song volume, incoming calls and new Bluetooth connections.
  • Built for fitness
    Tackle even the tough workouts with a design that's durable and sweatproof to withstand any element.
  • Sweatproof
    Water-resistant design uses hydrophobic nano coating to keep Flyer rain, splash and sweatproof.
  • Premium wireless sound
    Get sound that's precision engineered for crisp audio, powerful bass and dynamic range enhanced by WavesMaxx audio.
  • Music & call controls
    Adjust sound, pause or change songs and answer or end calls with the streamlined 3-button control box.
  • Dual microphone
    Get high-quality, hands-free calls in any environment with a dual microphone that suppresses external noise like wind.
  • Adjustable cable
    Adjustable cable ensures that headphones stay comfortable and secure during high-intensity workouts and all day.
Fitbit Flyer - earphones with mic
Earphones - Bluetooth - wireless
Nightfall blue
Headphones Form Factor
In-ear
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.2
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz
Noise Isolating
Noise isolating
2.49 cm
1.8 cm
2 cm
Nightfall blue
Audio Output
In-ear
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.2
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Stereo
Noise Isolating
Frequency Response
20 - 20000 Hz
Total Harmonic Distortion (THD)
0.5%
Diaphragm
8.6 mm
Simultaneously Connectable Devices Qty
2
Microphone
Built-in
Frequency Response
100 - 7000 Hz
Carrying case, 3 pairs of ear tips, 2 pairs of EarWings
Cable Details
Micro-USB charge cable - 50 cm
Run Time (Up To)
6 hour(s)
Recharge Time
2 hour(s)
Warranty
Warranty
2 years
