Fitbit Charge 3 Fitness Tracker - Black / Graphite Aluminium
Quicklinx: DV4PWS00 Mfr#: FB409GMBK-EU
Device Type: Wearable Tech
Type: Tracker
Stock Status: In Stock, Used Stock
Colours:
  • Bluetooth
47 in stock
£79.17 ex VAT
£95.00 inc VAT
Express delivery Order within the next 8 hours for delivery tomorrow
Charge 3
Fitbit's most advanced tracker ever
Fitbit Charge 3 helps you know your body and understand your health so you can take action to improve yourself.
24/7 Heart Rate
Goal-Based Exercises
Swimproof
Sleep Tracking & Stages
Smartphone Notifications
Up to 7 Day Battery
Know yourself on a whole new level
Fitbit Charge 3™ reveals insights about your body, your fitness and everything in between–because the better you know yourself, the better you can be.
24/7 Heart Rate
Charge 3 uses our most advanced heart rate sensors and algorithms to uncover meaningful insights on your heart.
All Day Calorie Burn
Know how many calories you’re really burning and use what you learn to reach your goals.
Real-Time Heart Rate Zones
See when you’re in Fat Burn, Cardio or Peak zones to make the most of every workout.
Auto Sleep Tracking
See how long you’re in light, deep and REM sleep and get personalized insights to learn how to get better rest.
Female Health Tracking
Use Fitbit Charge 3 with the Fitbit app to track periods, record symptoms and estimate ovulation and fertility windows.
Fitbit App Dashboard
Set goals, find inspiration, connect with friends and get a snapshot of your health and fitness all in one place.
Get guidance to make moves on your goals
The more you wear Charge 3, the more you learn about yourself and your workouts so you can start making changes that matter.
7 Day Battery
A multi-day battery life keeps insights and inspiration coming day and night. Varies with use and other factors.
Smarter, Sharper Touchscreen
The large, backlit display automatically adjusts to lighting conditions so you can easily see stats any time of day.
Durable, Lightweight Design
With aerospace-grade aluminum, a smooth-flush case and Corning® Gorilla® Glass 3, Charge 3 is comfortable and durable.
  • More ways to know & improve yourself
    Packed with motivating insights on your wrist, Charge 3 helps you better understand your heart health, sleep quality, workouts and more.
  • A smart way to stay connected
    With updates from your favorite smartphone apps, call alerts, text notifications and quick replies, Charge 3 makes sure you never miss a beat on your journey.
  • Built for the way you move
    With a large touchscreen and backlit display that automatically adjusts to lighting conditions, Fitbit Charge 3 makes it easier to see stats, notifications or the time in sunlight, at night & more.
Fitbit Charge 3 - graphite - activity tracker with sport band - black
Activity tracker
Bluetooth
Supported Host Device OS
iOS, Android, Windows Phone
Display
Monochrome OLED
Tracking Data
Distance, time, calories burned, activity, sleep activity, heart rate, steps taken, pace, sleep stages
Band
Black - sport band
Heart rate sensor, calendar notification, SMS notification, tap control, PurePulse heart rate technology, changeable band, automatic exercise recognition, SmartTrack, inactivity alert
Battery Run Time
Up to 7 day(s)
Case Material
Aerospace-grade aluminium
11.8 mm x 28.8 mm
30 g
1-year warranty
Activity tracker
Integrated Components
Heart rate sensor
Tracking Data
Wearing Style
Wrist
Clock Display
Set Goals
Calendar notification, SMS notification, tap control, PurePulse heart rate technology, changeable band, automatic exercise recognition, SmartTrack, inactivity alert
Display
OLED - monochrome
Wireless Interface
Bluetooth
Run Time (Up To)
7 day(s)
Smart Watch Case
Case Details
Graphite
Band
Name
Sport band
Clasp Type
Buckle
11.8 mm
28.8 mm
30 g
Vibrating Alert
Body Material
Protection
Waterproof
Warranty
1-year warranty
Max Depth of Water Resistance
50 m
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: DV4P 041432
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £60.06
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: Tracker
Brand: Fitbit
Stock Status: Used Stock
Price Range Ex VAT: 50 - 100
