Fitbit Blaze, Blue / Stainless Steel - Small
Quicklinx: CPNTWS00 Mfr#: FB502SBUS-EU
Colours:
Get fit in style with a smart fitness watch built with revolutionary features like PurePulse® heart rate, Connected GPS, on-screen workouts and more. Need music to work out to? Music control on your Blaze allows you to adjust volume, play, pause, or switch songs from your smartphone with just a simple tap. Packed full of features like all-day activity & sleep reminders, and interchangeable accessories, Blaze keeps you active and stylish. Start your day right and wake up to a silent alarm with the Fitbit app! Or why not try a Fitstar workout on your tracker and get step-by-step coaching and instructions?
Be in control
- Control your music, straight from your Blaze™! Play, pause, skip, and adjust the volume of your songs within your mobile playlist - great for working out.
- PurePulse® lets you monitor your heart rate, with automatic wrist-based heart rate tracking! Work towards your weight goals by monitoring your heart - it's in the middle of everything you do.
- Keep going all day, with the long battery life
- The Blaze™ syncs wirelessly and automatically to computers and over 200 leading iOS, Android and Windows devices
- Smartphone notifications pop up on your screen when your phone is nearby - receive calls, texts, calendar events, and push notifications from your favourite apps! (iOS and Android)
The Blaze™ listens to your body
- Tracks your all-day activity
- Gives you reminders to move when you've been static for too long
- Find moments of calm throughout your day with personalised breathing sessions based on your heart rate
- Auto sleep tracking, silent alarms & sleep stages automatically track your sleep quality, allow you to wake up peacefully, and gain insight into every stage of your sleep! Get a better understanding of your sleep quality.
Your new personal trainer
- Track workouts like running, biking, and weights, and get real time stats on the display!
- Workout summaries allow you to track improvements, straight from your wrist
- SmartTrack™ automatically recognises select activities and records it in the exercise section of the Fitbit app
- With connected GPS, see real-time stats like pace and distance
- Get a better understanding of your cardio fitness level and see how you can improve over time with your very own fitness score!
- On-Screen Workouts give you step by step instructions that can coach you through every move
Be you
Accessory bands & frames are availabe for when you'd like to customise your Blaze™!
Get ready to make a statement with the blue Blaze™ and the high-res touchscreen display, so you can clearly see your stats all day, every day!
  • PurePulse heart rate
    Get continuous, automatic, wrist-based heart rate and simplified heart rate zones.
  • Multi-sport
    Record running, cycling, cross training, weights and other workouts.
  • On-screen workouts
    Get workouts right on your wrist, with step-by-step instructions that coach you through each move.
  • Workout summaries
    See detailed workout summaries on your wrist and your improvements over time.
  • All-day activity
    Track steps, distance, calories burned, floors climbed and active minutes.
  • Smart notifications
    See call and text notifications and calendar alerts on display.
  • Auto sleep tracking and silent alarms
    Monitor your sleep automatically and set a silent alarm.
  • Music control
    Adjust your volume, and play, pause and skip songs from your mobile playlist.
  • Long battery life
    Lasts longer with an extended battery life.
  • Water resistant
    Sweat-, rain- and splashproof.
Fitbit Blaze smart watch with band - blue
Smart watch
Tracking Data
Distance, time, calories burned, activity, sleep activity, heart rate, steps taken, floors climbed
Bluetooth
Display
LCD
Case
Stainless steel
Band
Blue - band - elastomer - size: S - changeable
Input
Touch screen
Fits Wrist with Circumference
140-170 mm
Notifications
Missed calls, calendar, SMS
Music remote handling, HR zones, PurePulse heart rate technology, automatic exercise recognition, changeable frame
Supported Host Device OS
iOS, Android, Windows Phone
Lithium polymer
Battery Run Time
Up to 5 day(s)
42 mm
Smart watch
Notifications
Tracking Data
Wearing Style
Watch style
Clock Display
Set Goals
Sensors
Ambient light sensor, altimeter, 3-axis accelerometer
Display
LCD - colour
Wireless Interface
Bluetooth 4.0
Input Device
Touch sensitive screen
Lithium polymer
Run Time (Up To)
5 day(s)
Recharge Time
2 hour(s)
Band
Name
Band
Changeable
Size
S
140-170 mm
Clasp Type
Buckle
Material
Elastomer
Blue
42 mm
Preloaded Software
Clock, Silent alarm
System Requirements for PC Connection
Microsoft Windows Vista or later, Apple MacOS X 10.6 or later
Vibrating Alert
Body Material
Stainless steel
Protection
Weatherproof, splashproof, sweatproof
USB charging cable
Max Depth of Water Resistance
10 m
-10 °C
45 °C
Max Altitude Operating
8535 m
