Get fit in style with a smart fitness watch built with revolutionary features like PurePulse® heart rate, Connected GPS, on-screen workouts and more. Need music to work out to? Music control on your Blaze allows you to adjust volume, play, pause, or switch songs from your smartphone with just a simple tap. Packed full of features like all-day activity & sleep reminders, and interchangeable accessories, Blaze keeps you active and stylish. Start your day right and wake up to a silent alarm with the Fitbit app! Or why not try a Fitstar workout on your tracker and get step-by-step coaching and instructions?
Be in control
- Control your music, straight from your Blaze™! Play, pause, skip, and adjust the volume of your songs within your mobile playlist - great for working out.
- PurePulse® lets you monitor your heart rate, with automatic wrist-based heart rate tracking! Work towards your weight goals by monitoring your heart - it's in the middle of everything you do.
- Keep going all day, with the long battery life
- The Blaze™ syncs wirelessly and automatically to computers and over 200 leading iOS, Android and Windows devices
- Smartphone notifications pop up on your screen when your phone is nearby - receive calls, texts, calendar events, and push notifications from your favourite apps! (iOS and Android)
The Blaze™ listens to your body
- Tracks your all-day activity
- Gives you reminders to move when you've been static for too long
- Find moments of calm throughout your day with personalised breathing sessions based on your heart rate
- Auto sleep tracking, silent alarms & sleep stages automatically track your sleep quality, allow you to wake up peacefully, and gain insight into every stage of your sleep! Get a better understanding of your sleep quality.
Your new personal trainer
- Track workouts like running, biking, and weights, and get real time stats on the display!
- Workout summaries allow you to track improvements, straight from your wrist
- SmartTrack™ automatically recognises select activities and records it in the exercise section of the Fitbit app
- With connected GPS, see real-time stats like pace and distance
- Get a better understanding of your cardio fitness level and see how you can improve over time with your very own fitness score!
- On-Screen Workouts give you step by step instructions that can coach you through every move
Be you
Accessory bands & frames are availabe for when you'd like to customise your Blaze™!
Get ready to make a statement with the blue Blaze™ and the high-res touchscreen display, so you can clearly see your stats all day, every day!
PurePulse heart rate
Get continuous, automatic, wrist-based heart rate and simplified heart rate zones. -
Multi-sport
Record running, cycling, cross training, weights and other workouts. -
On-screen workouts
Get workouts right on your wrist, with step-by-step instructions that coach you through each move. -
Workout summaries
See detailed workout summaries on your wrist and your improvements over time. -
All-day activity
Track steps, distance, calories burned, floors climbed and active minutes. -
Smart notifications
See call and text notifications and calendar alerts on display. -
Auto sleep tracking and silent alarms
Monitor your sleep automatically and set a silent alarm. -
Music control
Adjust your volume, and play, pause and skip songs from your mobile playlist. -
Long battery life
Lasts longer with an extended battery life. -
Water resistant
Sweat-, rain- and splashproof.
- Fitbit Blaze smart watch with band - blue
- Product Type
- Smart watch
- Tracking Data
- Distance, time, calories burned, activity, sleep activity, heart rate, steps taken, floors climbed
- Connectivity
- Bluetooth
- Display
- LCD
- Case
- Stainless steel
- Band
- Blue - band - elastomer - size: S - changeable
- Input
- Touch screen
- Fits Wrist with Circumference
- 140-170 mm
- Notifications
- Missed calls, calendar, SMS
- Music remote handling, HR zones, PurePulse heart rate technology, automatic exercise recognition, changeable frame
- Supported Host Device OS
- iOS, Android, Windows Phone
- Battery
- Lithium polymer
- Battery Run Time
- Up to 5 day(s)
- 42 mm
- Product Type
- Smart watch
- Notifications
- Tracking Data
- Wearing Style
- Watch style
- Clock Display
- Set Goals
- Sensors
- Ambient light sensor, altimeter, 3-axis accelerometer
Display
- LCD - colour
- Wireless Interface
- Bluetooth 4.0
Input Device
- Touch sensitive screen
- Technology
- Lithium polymer
- Run Time (Up To)
- 5 day(s)
- Recharge Time
- 2 hour(s)
Band
- Name
- Band
- Changeable
- Size
- S
- 140-170 mm
- Clasp Type
- Buckle
- Material
- Elastomer
- Blue
- 42 mm
- Preloaded Software
- Clock, Silent alarm
- System Requirements for PC Connection
- Microsoft Windows Vista or later, Apple MacOS X 10.6 or later
- Vibrating Alert
- Body Material
- Stainless steel
- Protection
- Weatherproof, splashproof, sweatproof
- Included Accessories
- USB charging cable
- Max Depth of Water Resistance
- 10 m
- -10 °C
- 45 °C
- Max Altitude Operating
- 8535 m
