Fitbit Aria 2 WiFi Smart Scale - White
Quicklinx: DCZ1WS00 Mfr#: FB202WT-EU
Device Type: Wearable Tech
Stock Status: Clearance, Used Stock
Sorry but this product has been discontinued.
View used stock
Get better results with smarter scales that automatically track weight, body fat, BMI and lean mass and show your trends over time.
  • Track weight and more in just one step
  • Share the scales, not your stats
    Aria 2 recognizes up to eight users while keeping stats private which means your personal weight data is for your eyes only.
Fitbit Aria 2 - bathroom scales - white
Bathroom scales - electronic
Maximum Weight
180 kg
Maximum Weight (US)
400 lbs
White
31.2 cm x 31.2 cm x 3.3 cm
1.81 kg
2 year warranty
Category
Personal health
White
Scales
Maximum Weight
180 kg
Maximum Weight (US)
400 lbs
Weight Units
Kg, lb, st
Measuring Functions
Body fat percentage, body mass index (BMI)
Platform Material
Glass
Settings, Controls & Indicators
8 user memory
Smart Phone Compatible
Display
LCD display
AA battery x 3
Power Source
Battery Form Factor
AA
Required Battery Qty
3
31.2 cm
31.2 cm
3.3 cm
1.81 kg
Warranty
2 year warranty
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: DCZ1 042882
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £59.72
Ref: DCZ1 042903
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £63.65
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Fitbit
Stock Status: Used Stock
Price Range Ex VAT: 50 - 100
