Fellowes Smart Suites Monitor Riser / Monitor Stand
Quicklinx: 6KSQWS00 Mfr#: 8020101
Accessory Type: [N/A]
More than 50 in stock
£13.81 ex VAT
£16.57 inc VAT
Declutter your desktop and raise your monitor to a more comfortable level. Great for maximising desk space, this monitor stand fits neatly into a corner and allows for document storage.
  • Raises your screen to eye level to prevent neck strain
  • Supports up to a 21" flat panel monitor or a maximum weight of 10kgs
  • Includes three different height positions: 100mm, 115mm & 130mm
  • Ergonomic Riser
    Stylish monitor riser featuring three different height positions
Fellowes Smart Suites Corner Monitor Riser - stand
Stand
47 cm x 31.8 cm x 13 cm
Adjustable Height
10-13 cm
Adjustments
712 g
Recommended Use
Monitor
Recommended Display Size
21"
Max Load Weight
18.1 kg
Material
Acrylonitrile butadiene styrene (ABS)
3-year warranty
47 cm
31.8 cm
13 cm
Adjustable Height
10-13 cm
712 g
Material
AV Furniture
Stand
Recommended Use
Monitor
21"
Adjustments
Max Load Weight
18.1 kg
Adjustable height
Limited warranty - 3 years
Fellowes Smart Suites Monitor Riser / Monitor Stand Bundle deal on Fellowes Smart Suites Monitor Riser / Monitor Stand
£106.84
Brand: Fellowes
Price Range Ex VAT: 0 - 50
