Elevates Flat panel monitors to optimal viewing height with four fixed height positions offering up to 100mm adjustment. Vertical tilt adjustment (45 to -45°) and 360° swivel. VESA compliant. Supports screens up to 9kg and 21". Easy to mount two piece clamp.
Ergonomic Product
Stylish space saving flat panel monitor arm with four height positions Tilts, pivots, rotates and supports up to 9kgs
- Fellowes Designer Suites Flat Panel Monitor Arm mounting kit - for flat panel
- Product Type
- Mounting kit
- Mounting Components
- Support arm, desk clamp mount
- 12.1 cm x 36.8 cm x 61 cm
- Adjustments
- Tilt
- 2 kg
- Recommended Use
- Flat panel
- Recommended Display Size
- 21"
- VESA Mounting Interface
- Max Load Weight
- 9.1 kg
- 12.1 cm
- 36.8 cm
- 61 cm
- 2 kg
AV Furniture
- Mounting kit
- Recommended Use
- Flat panel
- Cable Management
- Cable Management System (CMS)
- 21"
- Adjustments
- Tilt
- Max Load Weight
- 9.1 kg
- Adjustable height, rotating
