Fellowes Smart Suites Flat Panel Monitor Arm
Quicklinx: B32DWS00 Mfr#: 8038201
Elevates Flat panel monitors to optimal viewing height with four fixed height positions offering up to 100mm adjustment. Vertical tilt adjustment (45 to -45°) and 360° swivel. VESA compliant. Supports screens up to 9kg and 21". Easy to mount two piece clamp.
  • Ergonomic Product
    Stylish space saving flat panel monitor arm with four height positions Tilts, pivots, rotates and supports up to 9kgs
Fellowes Designer Suites Flat Panel Monitor Arm mounting kit - for flat panel
Mounting kit
Mounting Components
Support arm, desk clamp mount
12.1 cm x 36.8 cm x 61 cm
Adjustments
Tilt
2 kg
Recommended Use
Flat panel
Recommended Display Size
21"
VESA Mounting Interface
Max Load Weight
9.1 kg
12.1 cm
36.8 cm
61 cm
2 kg
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Flat panel
Cable Management
Cable Management System (CMS)
21"
Adjustments
Tilt
Max Load Weight
9.1 kg
Adjustable height, rotating
