The Fellowes Powershred P-48C Cross-Cut shredder with added safety is ideal for moderate shredding requirements in the home / home office environment. The Security Level P-3 shredder can shred 8 sheets per pass into 4x50mm cross-cut particles. The machine features a Safety Lock allowing you to disable the shredder preventing accidental activation for added peace of mind. Make the most of the sheet capacity selector that allows you to measure the sheets before inserting them into the paper entry to avoid paper jams; it also features a wide 230mm paper entry and can shred continuously for up to 5 minutes. The 18 litre bin with lift-off head makes emptying paper waste hassle free. The Fellowes P-48C is capable of shredding staples, paperclips and credit cards and comes with a 2 year full warranty and 3 years on cutters.
- Fellowes Powershred P-48C - shredder
- Shredder
- Security Level
- S3
- Cut Type
- Cross-cut
- Shred Size
- 3.9 x 50 mm
- Wastebin Capacity
- 18 litres
- Number Of Sheets At Time
- 8
- Paper Entry Width
- 22.5 cm
- Shreds
- Credit cards, staples, paper clips, paper
- 5.9 kg
- 1 year
- Shredder
- Warranty Details
- Cutter: 3 years , Machine: 1 year
Shredder
- Security Level
- S3
- Cut Type
- Cross-cut
- Shred Size
- 3.9 x 50 mm
- Wastebin Capacity
- 18 litres
- 8
- Paper Entry Width
- 22.5 cm
- Shreds
- Continuous Run Time (minutes)
- 3-5 on/15 off
- Motor Reverse
- Autostart
- Yes (mechanical)
- Autostop
- Yes (mechanical)
- Safety cut-out
- 5.9 kg
- Shipping Width
- 41.2 cm
- Shipping Depth
- 30.8 cm
- Shipping Height
- 40.6 cm
