Supports up to 36kg in weight or 21" CRT or TFT/LCD monitor. Height adjustable with three positions 75mm-110mm. Lower shelf provides storage for paper and small supplies. Efficiently organises monitor and power cables.
Ergonomic Monitor riser
Adjustable riser support for monitors up to 36kgs, 21" screen size. Includes storage shelf
- Fellowes Monitor Riser stand - for Monitor - platinum, translucent graphite
- Product Type
- Stand
- Recommended Use
- Monitor
- Recommended Display Size
- Up to 21"
- Max Load Weight
- 36 kg
- Platinum, translucent graphite
AV Furniture
- Stand
- Recommended Use
- Monitor
- Up to 21"
- Max Load Weight
- 36 kg
- Adjustable height
