Introducing the EZVIZ 3x wire-free Wi-Fi Battery Camera & Hub
The EZVIZ Battery Camera is a weatherproof indoor/outdoor standalone 100% wire-free, battery-powered security camera. It enables the user to effortlessly and seamlessly place it anywhere without any hassles of dealing with cables. This pack comes with 3x wire-free battery Cameras.
The EZVIZ W2D base station prolongs the battery life of the EZVIZ wire-free camera by up to 9 months. (Work Condition: Normal temperature and environment, triggered 5min/Day). The Hub Works with up to six EZVIZ wire-free Battery cameras
Furthermore, the Hub has a built-in 100db Siren so that when motion is detected you can choose via the EZVIZ app if you want an automatic or manual siren activation to occur.
A wide range of accessories are also available to enhance your wire-free Battery Camera experience, including a solar power panel, charging station, and metal mount for more secure installation.
Rechargeable Battery for EZVIZ wire-free camera
Long Life 5500mAh Rechargeable lithium battery for the wire-free camera that can last up to 3 months on its own, but when used with the EZVIZ Hub, battery life can be prolonged up to 9 months. In both instances this is subject to your environmental conditions and usage levels.
Smart Human Detection & Instant Alerts
Featuring PIR human detection, the wire-free camera sends an instant alert to you when a human is approaching. With two-way audio you can also communicate via the EZVIZ app.
HD Video with Wide-Angle View & Night Vision
With its HD 1080p wide-angle lens, the C3A gives you a convenient 126 degrees’ view. The wire-free camera also features up to 5 meters of night vision and delivers crystal clear images even at night. The video switches between day and night modes automatically.
Designed for All Conditions
The EZVIZ wire-free camera comes with clear, 5m night vision and an IP65 weatherproof design.
One App Does All the Work
All you need to do for setup is follow the instructions via the free EZVIZ app and your home Wi-Fi. The EZVIZ app works with all EZVIZ Cameras and alarm products. View and manage remotely wherever you are.
Storage of footage
EZVIZ cameras can hold a MicroSD card for local and continuous storage, alternatively you can sign up to our Cloud Storage system (subject to subscription) or via an EZVIZ Network Video Recorder (NVR).
Further Recommendations Consider a Wi-Fi Range Extender if you have poor connectivity around the home from your Router location
Works with Amazon Alexa, Google Assistant & EZVIZ Alarm Systems
- EZVIZ C3A - network surveillance camera - with EZVIZ W2D base station
- Network surveillance camera - fixed - outdoor, indoor - dustproof / weatherproof
- Packaged Quantity
- 3 (specifications are for single item)
- Bundled with
- EZVIZ W2D base station
- Audio
- Yes: built-in speaker, two-way audio capability, built-in microphone
- 5.608 cm x 7.002 cm x 9.209 cm
- 215 g
- Connectivity Technology
- Wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 30 frames per second
- Motion Detection
- Video Modes
- 1080p
- Optical Sensor Type
- CMOS - 1/4" - 2 MP
- Focal Length Control
- Fixed focal
- Focal Length
- 2.2 mm
- Lens Iris
- F/2.4
- Wi-Fi
- Voltage
- DC 5 V
- Saturation control, brightness control, contrast control, image mirror, automatic electronic shutter, Motion Detection Technology, infrared cut filter, Digital Wide Dynamic Range (D-WDR), dual video stream, password protection, flickerless, Variable Bitrate (VBR), cloud recording, 3D Digital Noise Reduction Technology
- Environmental Parameters (operating)
- -20 °C - 45 °C; 0 - 95% (non-condensing) relative humidity
- Packaged Quantity
- Audio Support
- Wireless
- 5.608 cm
- 7.002 cm
- 9.209 cm
- 215 g
- Localisation
- Europe
- Bundled with
Camera
- Colour - Day&Night - fixed - outdoor, indoor - dustproof / weatherproof
- Digital Video Format
- H.264
- Max Digital Video Resolution
- 1920 x 1080
- Motion Detection
- Video Modes
- 1080p
- Infrared LEDs
- Infrared Distance
- 7.5 m
- Digital Video Capture Resolution
- 1920 x 1080
- Frame Rate (max)
Image Sensor
- 2 MP CMOS 1/4"
Lens Construction
- Fixed focal
- Focal Length
- 2.2 mm
- Lens Iris
- F/2.4
- Horizontal Field of View (degree)
- 126
- Network Interface
- Wi-Fi
- Supported Memory Cards
- microSD Card, microSDHC Card, microSDXC Card
- IP65
- Power Requirements
- DC 5 V - 1.5 A
- Power Device
- Power adapter - external 5 Watt
- Battery
- Lithium Ion 5500 mAh
- -20 °C
- 45 °C
- Relative Humidity (operating)
- 0 - 95% (non-condensing)
