Ezviz Smart Video Doorbell
Quicklinx: F8Z9WS00 Mfr#: CS-DB1-A0-1B3WPFR
Type: Doorbell camera
Compatible With: Alexa, Google Assistant, IFTTT
30 in stock
£112.49 ex VAT
£134.98 inc VAT
Introducing the EZVIZ Video Doorbell with PIR
EZVIZ’s Video Doorbell has a 3MP Resolution camera and Weatherproof casing for Outdoor use. It’s 180-degree vertical viewing angle and 105-degree horizontal view, lets you see who’s there from head to toe and even talk to them when you are not home. Connect it to your smartphone via the EZVIZ app to keep your home safe. It also comes with 3 different angle plates and 3 different colour facia plates for optimum look and view. Professional Installation Recommended, available via ezvizlife.com/uk
Answer the door from anywhere
The Doorbell initiates a video call via the EZVIZ App when someone rings your doorbell, so you’ll never miss a visitor. See and talk to your visitors from your smartphone anywhere, any time. The built-in microphone and speaker make it easy for you to hear what’s happening outside the door.
Be Informed
Featuring PIR technology to help reduce false triggers, it simply detects heat sources only, such as Cars, Animals and Humans near or approaching your door. Motion Detection Alerts will trigger a notification to be sent to your smartphone via the EZVIZ app which brings attention to the event occurring from wherever you are.
Amazon Alexa & Google Home Compatible
Using the sound of your voice you can view live footage via your Amazon Alexa and Google Hub
Secure Your Home Day & Night
The lens is circled by IR LEDs for clear video even when it’s dark, giving clear night vision and recording, providing 24/7 security in your home or office.
Two-way Talk
The internal microphone supports audio pickup within five meters and video recording with sound, meaning you can have a two-way conversation if needed via the EZVIZ app.
Easy Setup
For product setup simply follow the instructions via the EZVIZ app to connect it to your Wi-Fi and complete the setup process.
App Features
With the EZVIZ app you can manage and view your camera live. In addition to this you can set schedules, create detection areas and review/share previous footage.
Storage of footage
EZVIZ cameras can hold a MicroSD card (up to 128GB) for local storage upon each detection, or alternatively you can sign up to our Cloud Storage system (subject to subscription costs)
Works with EZVIZ Alarm Systems
Link to a specific EZVIZ alarm sensor via the app to ensure footage begins straight away when a sensor is triggered. Furthermore, one set via the app, the Pan/Tilt feature will automatically move direction towards the sensor in question helping capture the whole event from all angles.
What’s in the box
  • 1x EZVIZ 3MP Video Doorbell
  • 3x Mounting Angle Accessories
  • 3x Colour Facia Plates (Black, White and Bronze)
  • 1x Screw and wire kit
  • 1x Quick Start Guide
  • From head to toe, every detail is there
    Even a tiny package on the ground is easily captured by the DB1, thanks to its 180° vertical field of view and high-quality 3 megapixel video.
  • Answer the door from anywhere
    The DB1 initiates a video call via the EZVIZ app when someone rings your doorbell, so you'll never miss a visitor.
  • Get intelligent alerts with two-way talk
    See and talk to your visitors from your smartphone anywhere, any time. The built-in microphone and speaker make it easy for you to hear what's happening outside the door.
  • Be the first to know who's there
    Featuring PIR human detection, the DB1 sends an instant alert to you when a visitor is approaching. The DB1 also lets you customize the detection area, so you'll only get efficient alerts from the area you want to have your eyes on.
  • Designed for all conditions
    The DB1 comes with clear, 5-meter night vision and an IP65 weatherproof design, so you can see who is at your door any time of day and in any kind of weather.
EZVIZ DB1 - doorbell camera
Doorbell camera
Functions
Motion detection, camera
Power Source
Hardwired
Wireless - Wi-Fi
Frequency Band
2.4 Ghz, 5 GHz
Camera
1/2.8" - Max Resolution 2048 x 1536 - audio - Day&Night
4.6 cm x 2.1 cm x 13 cm
Doorbell camera
Functions
Power Source
Hardwired
Wireless
Frequency Band
2.4 Ghz, 5 GHz
Waterproof, built-in microphone, built-in speaker, 2-way audio, microSD Memory Card slot
Camera
Image Sensor
1/2.8"
Lens Aperture
F/2.4
Focal Length
2.2 mm
Day & Night Functionality
Audio Support
Max Digital Video Resolution
2048 x 1536
Backlight compensation, weatherproof, Digital Wide Dynamic Range (D-WDR), 2-way voice communication, 3D digital noise reduction (DNR), 180° field of view (horizontal), 105° field of view (vertical)
Motion Sensor
Detection Mode
Passive infrared (PIR)
Nominal Voltage
AC 8 - 24 V
5 Watt
IP65
4.6 cm
2.1 cm
13 cm
125 g
Shipping Width
25 cm
Shipping Depth
19.2 cm
Shipping Height
7.55 cm
-30 °C
60 °C
0 - 95% (non-condensing)
Compatible With: IFTTT
Brand: Ezviz
Price Range Ex VAT: 100 - 150
