Ezviz Hub with built-in Siren works with Wire-free Battery
Quicklinx: F8ZCWS00 Mfr#: CS-W2D-EUP
Type: Gateway
Compatible With: Alexa, Google Assistant, IFTTT
£66.66 ex VAT
£79.99 inc VAT
Introducing the EZVIZ W2D Wi-Fi Base Station
The EZVIZ Hub prolongs the battery life of the EZVIZ wire-free camera by up to 9 months. (Work Condition: Normal temperature and environment, triggered 5min/Day). The Hub Works with up to six EZVIZ wire-free Battery cameras
Furthermore, the Hub has a built-in 100db Siren so that when motion is detected you can choose via the EZVIZ app if you want an automatic or manual siren activation to occur.
A wide range of accessories are also available to enhance your wire-free Battery Camera experience, including a solar power panel, charging station, and metal mount for more secure installation.
Hikvision CS-W2D-EUP Wire-Free Camera Base Station - gateway
Gateway
Environment
Indoor
Functions
Extending wireless transmission range, charging
Wireless - 802.11b/g/n - 10/100 Ethernet
Frequency Band
433 MHz, 868 MHz, 915 MHz, 2.4 Ghz
9.5 cm x 9.5 cm x 11 cm
EZVIZ C3A
Gateway
Environment
Indoor
Functions
Wireless
Frequency Band
100dB siren, LED indicator
Internet of Things (IoT)
LAN
Manufacturer
Qualcomm
Clock Speed
650 MHz
RAM
Installed Size
128 MB
Flash Memory
Installed Size
16 MB
Nominal Voltage
AC 120/230 V
10 Watt
9.5 cm
9.5 cm
11 cm
180 g
Shipping Width
11.95 cm
Shipping Depth
13 cm
Shipping Height
21.5 cm
EZVIZ C3A
Type: Gateway
Compatible With: IFTTT
Brand: Ezviz
Price Range Ex VAT: 50 - 100
