Ezviz HD Indoor Smart Security Cam
Quicklinx: F8YZWS00 Mfr#: CS-C1C-D0-1D1WFR
Type: Indoor Camera
Compatible With: Alexa, Google Assistant, IFTTT
  • microSD Card
  • microSDHC Card
More than 50 in stock
£24.99 ex VAT
£29.98 inc VAT
Express delivery Order within the next 16 hours for delivery tomorrow
Introducing the EZVIZ Indoor HD Camera
This starter camera is an ideal option to begin your experience with Smart Home Camera technology. The Indoor camera makes it easy to keep an eye on what’s happening in any room. Its magnetic base quickly clamps to any magnetic surface for easy setup if required. Once placed, you can adjust where the camera is aiming by simply moving it with your hand.
Baby/Pet Monitor
Great for monitoring your pets or little ones, furthermore with the two-way talk, you can see, hear and speak all through the EZVIZ app, whether you are at home or away!
Be Informed
Motion Detection Alerts will trigger a notification to be sent to your smartphone via the EZVIZ app which brings attention to the event occurring from wherever you are.
Amazon Alexa & Google Home Compatible
Using the sound of your voice you can view live footage via your Amazon Alexa and Google Hub
Secure Your Home Day & Night
Integrated Infrared technology for clear video even when it’s dark, giving clear night vision and recording, providing 24/7 security in your home or office.
Two-way Talk
The internal microphone supports audio pickup within five meters and video recording with sound, meaning you can have a two-way conversation if needed via the EZVIZ app.
Easy Setup
For product setup simply follow the instructions via the EZVIZ app to connect it to your Wi-Fi and complete the setup process.
App Features With the EZVIZ app you can manage and view your camera live. In addition to this you can set schedules, create detection areas and review/share previous footage.
Storage of footage
EZVIZ cameras can hold a MicroSD card (up to 256GB) for local continuous storage upon each detection, or alternatively you can sign up to our Cloud Storage system (subject to subscription costs) With a MicroSD card storage option, you can now choose the option of continuous recording within the app for this camera, meaning you will have constant monitoring as well as just motion detection recording.
What’s in the box
  • 1x EZVIZ HD WiFi Indoor Camera
  • 1x Power Adapter with 3m Cable (3.5mm jack connection)
  • 1x Quick Start Guide
EZVIZ C1C - network surveillance camera
Network surveillance camera - fixed
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
6.4 cm x 6.4 cm x 10.3 cm
96 g
Wireless
Camera
Colour - Day&Night
Max Resolution
1280 x 720
Frame Rate (max)
20 frames per second
Motion Detection
Video Modes
720p
Optical Sensor Type
CMOS - 1/4"
Focal Length Control
Fixed focal
Focal Length
2.8 mm
Lens Mounting
M12 mount
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
1 - micro-USB cable - 3 m
Progressive scanning, image mirror, infrared cut filter, Digital Wide Dynamic Range (D-WDR), dual video stream, password protection, WPA, WPA2-PSK, 64-bit WEP, 128-bit WEP, WPA-PSK, WPA2, watermark, heartbeat, anti-flicker, 3D digital noise reduction (DNR), self-adaptive shutter
Environmental Parameters (operating)
-10 °C - 45 °C; 0 - 95% (non-condensing) relative humidity
Audio Support
Wireless
6.4 cm
6.4 cm
10.3 cm
96 g
Camera
Colour - Day&Night - fixed
Digital Video Format
H.264
Max Digital Video Resolution
1280 x 720
Motion Detection
Video Modes
720p
Digital Zoom
8
Infrared Distance
12 m
Digital Video Capture Resolution
1280 x 720
Frame Rate (max)
Image Sensor
CMOS 1/4"
Lens Construction
M12 mount - fixed focal
Focal Length
2.8 mm
Horizontal Field of View (degree)
92
Diagonal Field of View (degree)
110
Network Interface
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
Metal plate, 2 foam stickers
1 x micro-USB cable - 3 m
UL, FCC, RoHS, WEEE, REACH
Power adapter 4 Watt
Shipping Width
12.3 cm
Shipping Depth
7.9 cm
Shipping Height
12.55 cm
-10 °C
45 °C
Relative Humidity (operating)
Type: Indoor Camera
Compatible With: IFTTT
Brand: Ezviz
Price Range Ex VAT: 0 - 50
