Ezviz DP2 Wire-Free Peephole Doorbell
Quicklinx: H0W2WS00 Mfr#: CS-DP2-A0-6E2WPFBS
Know who’s knocking, from the indoor touchable monitor or via your EZVIZ App. With simple taps on the big or small screen, you can see every detail with clear video quality. You can also set the ringtone as you like and talk to your visitors with ease. Protection is made simple with activity-triggered alerts, so you don’t miss a moment.
  • A useful touch screen made for everyone
    The large, colorful and touchable monitor is extremely easy use, even for the elderly and children. No more need to lean against the door to look through the tiny peephole. You will know who's outside by pressing the home button. The screen can also be set to automatically turn on upon detection of visitors.
  • Get the whole picture in front of your door in Full HD
    The DP2 helps reduce blind spots with a wide 166-degree visual coverage, and captures details in sharp 1080p.
  • Greet every visitor with calm and ease
    Working as a peephole camera and a doorbell, the DP2 ensures both security and convenience. Know instantly who is at your door, why and how to handle the situation even you are far away from home. There is even a voice changer if you'd prefer to remain unidentifiable to a stranger.
  • Smarter detection tells you what you want to know
    Integrating PIR motion detection with human shape detection, the DP2 is designed to reduce false alarms caused by trivial moving objects. Whether you live near a busy street or in a quiet neighborhood, you can customize the detection sensitivity to receive alerts that you care about.
  • Wire-free protection with 3-month battery life
    The DP2 features a 4,600 mAh rechargeable lithium battery. The standby time can reach up to 90 days with the smart power-saving functionality.
  • Built to last
    Made with high-endurance zinc alloy, the DP2 is both sturdy enough for the outdoors and stylish enough to fit your front-door style.
  • Safe, flexible storage options
    Save videos locally on a 256 GB storage card, which can be inserted onto the indoor monitor. This guarantees data security in case the outdoor camera is damaged. Or, if you prefer, subscribe to EZVIZ CloudPlay for fully encrypted cloud storage.
EZVIZ DP2 - video intercom system - wireless (802.11b, 802.11g, 802.11n) - hardwired, battery powered
System
Video intercom system - wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n - 2.4 GHz - hardwired, battery
Monitor
4.3" LCD monitor - colour
Camera
1 cameras - night vision
Silver
320 g
2 years
System
Network Interface
Wireless Frequency Band
2.4 GHz
2-way audio, built-in microphone, built-in speaker, PIR sensor, 1080p HD video, doorbell button, microSDXC card slot, touch screen, Digital Wide Dynamic Range (WDR), built-in battery (4600 mAh)
Package Content
Monitor, doorbell unit, power cable, screw kit, mounting base
Power Source
Hardwired, battery
Motion Detection Range
6 m
Silver
UL, FCC, RoHS, AES-128, WEEE, REACH, TLS, WPA-PSK, WPA2-PSK, WEP, WPA, WPA2
Warranty
2 years
Monitor
Diagonal Size
4.3"
LCD monitor
Security DVR
Compression Format
H.265
Cameras
Quantity
1 cameras
Sensor
CMOS - 1/2.7" - 2 Megapixel
Field of View
136° (H), 80° (V), 166° (D)
Night Vision
Infrared Distance
5 m
Focal Length
2 mm
320 g
Details
Doorbell unit: 7.1 cm x 4.83 cm x 7.1 cm , Monitor: 11.55 cm x 2.45 cm x 8.55 cm
Shipping Weight
603 g
