Product
Evoluent Hypertec Evoluent VerticalMouse 4
Quicklinx: 93JCWS00 Mfr#: VM4R
The patented shape supports your hand in an upright neutral posture that generally avoids forearm twisting. The Evoluent VerticalMouse provides superior comfort and even relieved their wrist pain.
  • Comfortable and easy to use
    The shape is thoughtfully sculpted for uncompromised comfort and easy-to-reach programmable buttons. No finger contortions are needed to operate the buttons.
  • Adjustable laser sensor
    Pointer speed controls on the side allow convenient adjustment without even releasing your grip from the mouse.
  • Improved thumb rest
    The thumb rest has been reshaped to provide even more comfort over earlier versions.
  • Extended lip prevents rubbing
    An extra wide lip along the bottom edge prevents the last finger from rubbing the desk.
Evoluent VerticalMouse 4 - mouse - USB
Mouse - ergonomic
Wired - USB
Orientation
Right-handed
Movement Detection Technology
Optical
Buttons Qty
6
Scrolling wheel, Pointer speed indicators, 6 programmable buttons, on-the-fly DPI switching with 4 stage LED light indicator, illuminated logo, thumb rest
Apple MacOS, Linux, Microsoft Windows XP / Vista / 7 / 8 / 10 (32/64 bits)
Mouse
Ergonomic Design
Orientation
Right-handed
Input Device
Wired
USB
Optical
Buttons Qty
6
1 x USB - 4 pin USB Type A
