ABSOLUTE CONTROL
Introducing the EVGA TORQ X5 gaming mouse.
Built with the highest quality materials, this mouse was designed from the ground up to satisfy the needs of the hardcore gamer with a high quality optical sensor that provides up to 6400 DPI, eight programmable buttons, and a customizable RGB LED.
The EVGA TORQ X5 features the highest quality Omron switches with a lifespan of over 20 million clicks, 512Kb of onboard storage for saving up to 5 separate profiles, robust tuning software, a Pixart 3988 Optical sensor providing up to 6400DPI with 1000Hz polling rate, and much more.
- Onboard storage can support up to 5 separate profiles
- Ambidextrous design supports right or left handed gamers
- Adjustable DPI with On-the-Fly Sensitivity adjustment
- Highest quality materials and Omron switches
- Robust software allows full control over mouse including Macro setup, profiles and OSD
- Super low friction PTFE mouse feet
Awards
KitGuru, 2015/05/01
- EVGA's latest mouse is one of the best mice we have reviewed this year and it is one of the cheapest too. A must have for gamers on a budget.
Game Fanatics, 2015/04/01
- "The EVGA Torq X5 is an affordable gaming mouse that won't break the bank. If you're thinking about buying your first gaming mouse or just in the market for a new mouse you can't go wrong with the EVGA Torq X5."
Techgage, 2015/03/01
- It's easily one of the best mice I've ever reviewed. It has no real weaknesses, plus it's got features, functionality, and build quality that you'd typically find only in more expensive competitors.
The Tech Report, 2015/03/01
- "I love its feathery weight and light button response. The X5's $50 price tag is quite reasonable, as well. With all of that goodness going for it, I'm happy to call the Torq X5 TR Recommended, and I'm looking forward to future gaming sessions with this mouse at hand."
Handware Canucks, 2015/02/01
- One of the best for $49!
ThinkComputers, 2015/02/01
- It has a great feel to it and is the perfect mouse for an FPS gamer. On top of that it has some nice styling and looks great sitting on your desk with 7 different LED colors to choose from.
Benchmark Reviews, 2015/02/01
- The performance of the mouse, with a 6400dpi sensor and 1kHz polling rate, was crisp and precise, every bit the equal of its big brother.
Modders-Inc, 2015/02/01
- Ambidextrous design done right
Max DPI: 6400
Sensor Type: Optical (Pixart 3988)
Main Switch Type: Omron - 20 Million Click Lifecycle
Programmable Buttons: 8 Weight: 85g (without cable)
Max Polling/Report Rate: 1000Hz
LED Color: Red, Green, Blue, Yellow, Orange, Pink, Purple
Feet Type: Low Friction PTFE
Max Number of Profiles: 5 (512K Onboard)
Height: 1.53in – 38.86mm
Length: 4.64in – 117.86mm
Width: 2.55in – 64.77mm
- EVGA TORQ X5 - mouse - USB
- Mouse
- Connectivity Technology
- Wired - USB
- Orientation
- Right and left-handed
- 6.477 cm x 11.786 cm x 3.8862 cm
- 85 g
- Movement Detection Technology
- Optical
- Buttons Qty
- 8
- Movement Resolution
- 6400 dpi
- Performance
- Polling rate: 1000 Hz
- Polytetrafluoroethylene (PTFE) feet, 7-colour LED, On-The-Fly Sensitivity, 5 profiles, On-screen Display (OSD), 8 programmable buttons, OMRON switches, Pixart 3988 optical sensor
- 3-year warranty
- Mouse
- Orientation
- 6.477 cm
- 11.786 cm
- 3.8862 cm
- 85 g
Input Device
- Wired
- Interface
- USB
- Optical
- Buttons Qty
- 8
- Memory
- 512 KB
- 6400 dpi
- Performance
- 1 x USB - 4 pin USB Type A
- Limited warranty - parts and labour - 3 years
