EVGA SuperNOVA 850W G2 Gold ATX PSU
Quicklinx: C6RLWS00 Mfr#: 220-G2-0850-X3
Based on the G2 series power supplies from EVGA, this PSU features 80 PLUS Gold rated efficiency, and clean, continuous power to every component. This provides improved efficiency for longer operation, less power consumption, reduced energy costs and minimal heat dissipation. The ECO thermal control fan system offers fan modes to provide zero fan noise during low load operations. Backed by a Japanese capacitor design, the EVGA SuperNOVA 850 G2 is not only the right choice for your system today, it is also the best choice for your system tomorrow.
EVGA SuperNOVA 850 G2 - power supply - 850 Watt
Power supply - internal
80 PLUS Certification
80 PLUS Gold
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
850 Watt
Output Current
+5V - 24 A , +5V - 24 A , +12V - 70.8 A , +5VSB - 3 A , -12V - 0.5 A
Output connectors
1 x power 24 pin ATX , 2 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 4 x 8 pin PCI Express power with detachable 2 pin section , 2 x 6 pin PCI Express power , 10 x 15 pin Serial ATA power , 4 x 4 PIN internal power , 1 x 4 PIN mini-power connector
Modular Cable Management
Cooling System
140 mm fan
10 years warranty
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
850 Watt
Output Current
Efficiency
90% (115VAC) / 92% (220-240VAC)
80 PLUS Gold
MTBF
100,000 hour(s)
Cooling System
140 mm fan
Over current protection, over voltage protection, overpower protection, SLI ready, CrossFire ready, undervoltage protection, short-circuit protection, dual ball bearing cooling fan, fully modular
TUV, BSMI, CB, FCC, RoHS, WEEE, cTUVus, RCM
Limited warranty - 10 years
50 °C
