Product
Brand
EVGA SuperNOVA 750W Gold PSU
Quicklinx: BWTYWS00 Mfr#: 220-G2-0750-X3
Unleash the next generation in power with the EVGA SuperNOVA 750 G2 Power Supply. Based on the award winning G2 series power supplies from EVGA, this PSU features 80 PLUS Gold rated efficiency, and clean, continuous power to every component. This provides improved efficiency for longer operation, less power consumption, reduced energy costs and minimal heat dissipation. The ECO thermal control fan system offers fan modes to provide zero fan noise during low load operations.
EVGA SuperNOVA 750 G2 - power supply - 750 Watt
Power supply - internal
Specification Compliance
ATX12V / EPS12V
80 PLUS Certification
80 PLUS Gold
2.72 kg
United Kingdom
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
750 Watt
Output connectors
1 x power 24 pin ATX , 2 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 4 x 8 pin PCI Express power with detachable 2 pin section , 9 x 15 pin Serial ATA power , 4 x 4 PIN internal power , 1 x 4 PIN mini-power connector
Cooling System
140 mm fan
10 years warranty
ATX12V / EPS12V
PSU Form Factor
ATX
United Kingdom
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
750 Watt
Output Current
+3.3V - 24 A , +5V - 24 A , +12V - 62.4 A , +5VSB - 3 A , -12V - 0.5 A
Efficiency
90% (115VAC) / 92% (220-240VAC)
Modular Cable Management
80 PLUS Gold
AC input cable - external - 1.5 m
MTBF
100,000 hour(s)
Cooling System
140 mm fan
Over current protection, over voltage protection, overpower protection, SLI ready, CrossFire ready, undervoltage protection, short-circuit protection, dual ball bearing cooling fan, fully modular
TUV, BSMI, CB, FCC, RoHS, WEEE, cTUVus, RCM, ErP Lot 6 2013 Ready
Limited warranty - 10 years
50 °C
2.72 kg
