The EVGA SuperNOVA 750 Power Supply is here with Gold Rated Efficiency. Designed with enthusiast needs in mind the SuperNOVA series are the best choice to power next generation enthusiast computers. Combining 750W of continuous power with exceptional performance, stunning efficiency, and cutting-edge design and features, the SuperNOVA series power supplies are what you need to take your system to the next level.
- EVGA SuperNOVA 750 G1 - power supply - 750 Watt
- Power supply - internal
- Specification Compliance
- ATX12V / EPS12V
- 80 PLUS Certification
- 80 PLUS Gold
- Input Voltage
- AC 100-240 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 750 Watt
- Output Current
- +3.3V - 25 A , +5V - 25 A , +12V1 - 20 A , +12V2 - 20 A , +12V3 - 20 A , +12V4 - 20 A , +5VSB - 3 A , -12V - 0.8 A
- Input Connectors
- Power IEC 60320 C14
- Output connectors
- 1 x power 24 pin ATX , 2 x power 8 pin +12V with detachable 4 pin section , 4 x 8 pin PCI Express power with detachable 2 pin section , 9 x 15 pin Serial ATA power , 6 x 4 PIN internal power , 1 x 4 PIN mini-power connector
- Modular Cable Management
- 10 years warranty
- ATX12V / EPS12V
- PSU Form Factor
- ATX
- Input Voltage
- AC 100-240 V
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 750 Watt
- Output Current
- Efficiency
- 90% (115VAC) / 92% (220-240VAC)
- 80 PLUS Gold
- Cables Included
- Power cable - external - 1.8 m
- Overheat protection, over current protection, over voltage protection, overpower protection, undervoltage protection, short-circuit protection
- Limited warranty - 10 years
