Product
EVGA SuperNOVA 750 P2 750W Platinum Fully Modular PSU
Quicklinx: BHYWWS00 Mfr#: 220-P2-0750-X3
The unbeatable performance of the EVGA SuperNOVA P2 power supply line is now available in 750 watts. Based on the award winning P2 power supplies, this unit features 80 Plus Platinum rated efficiency, and clean, continuous power to every component. The ECO Control Fan system offers fan modes to provide absolutely zero fan noise during low load to medium load operations. Backed by an award winning 10 year warranty, and 100% Japanese capacitor design, the EVGA SuperNOVA 750 P2 power supply offers unbeatable performance at an unbeatable value.
FEATURES
Unbeatable 10 Year Warranty and unparalleled EVGA Customer Support
Highest quality Japanese brand capacitors ensure longterm reliability
Fully Modular to reduce clutter and improve airflow
NVIDIA SLI & AMD Crossfire Ready
Double Ball Bearing fan for exceptional reliability and quiet operation
Heavyduty protections, including OVP (Over Voltage Protection), UVP (Under Voltage Protection), OCP (Over Current Protection), OPP (Over Power Protection), and SCP (Short Circuit Protection)
80 PLUS Platinum certified, with 92% (115VAC) / 94% (220VAC~240VAC) efficiency or higher under typical loads
EVGA SuperNOVA 750 P2 - power supply - 750 Watt
Power supply - internal
Specification Compliance
ATX / EPS
80 PLUS Certification
80 PLUS Platinum
3.63 kg
United Kingdom
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
750 Watt
Output connectors
1 x power 24 pin ATX , 2 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 4 x 8 pin PCI Express power with detachable 2 pin section , 2 x 6 pin PCI Express power , 10 x 15 pin Serial ATA power , 4 x 4 PIN internal power , 1 x 4 PIN mini-power connector
Cooling System
140 mm fan
Cable bag
15 cm x 16.5 cm x 8.5 cm
10 years warranty with product registration
ATX / EPS
PSU Form Factor
ATX
United Kingdom
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
750 Watt
Output Current
+5V - 20 A , +3.3V - 20 A , +12V - 62.4 A , -12V - 0.5 A , +5VSB - 2.5 A
Efficiency
92% (115VAC) / 94% (220-240VAC)
Modular Cable Management
80 PLUS Platinum
Cable bag
MTBF
100,000 hour(s)
Cooling System
140 mm fan
Over current protection, over voltage protection, overpower protection, SLI ready, CrossFire ready, undervoltage protection, short-circuit protection, single 12V rail, Eco-Mode, fully modular
TUV, BSMI, CB, FCC, RoHS, WEEE, cTUVus, Energy-Related Products (ErP) Lot 6, RCM
Limited warranty - parts and labour - 10 years with product registration
50 °C
15 cm
16.5 cm
8.5 cm
3.63 kg
