The unbeatable performance of the SVGA SuperNOVA G2 power supply line is now available in 550 watt. Based on the award winning G2 power supplies, these units feature 80 Plus Gold rated efficiency, and clean, continuous power to every component. The ECO control fan system offers fan modes to provide absolutely zero fan noise during load to medium load operations. Backed by 100% Japanese capacitor design, the SVGA SuperNOVA 550 G2 power supplies offer unbeatable performance at an unbeatable value.
Single +12 V rail
A single +12 V rail offers the best power output, rail stability and compatibility with the hardware. -
LLC resonant circuit layout
Full DC to DC, LLC resonant circuit design improves efficiency. -
Fully modular
Fully modular designs allows every single cable to be removed from the power supply for ease of installation and removal. You can also leave off unnecessary cables to reduce case clutter and maximize case airflow. -
Highest quality solid state capacitors
Get the most reliability and greatest performance with the use of the highest possible quality Japanese solid state capacitors. -
Double ball bearing fan
A high-quality dual-ball bearing fan gives the SuperNOVA 550 G2 an excellent thermal and acoustic profile, and its high reliability ensures a long PSU lifetime. -
80 Plus certification ensures your power supply isn't wasting power and turning it into excess heat. Under typical load this power supply is 90% efficient or higher.
- EVGA SuperNOVA 550 G2 - power supply - 550 Watt
- Power supply - internal
- 80 PLUS Certification
- 80 PLUS Gold
- 2.72 kg
- Input Voltage
- AC 100-240 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 550 Watt
- Output Current
- +3.3V - 22 A , +5V - 22 A , +12V - 45.8 A , +5VSB - 3 A , -12V - 0.5 A
- Output connectors
- 1 x power 24 pin ATX , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 9 x 15 pin Serial ATA power , 3 x 4 PIN internal power , 1 x 4 PIN mini-power connector , 2 x 8 pin PCI Express power with detachable 2 pin section , 1 x 8 pin PCI Express power
- Modular Cable Management
- Cooling System
- 140 mm fan
- 15 cm x 16.5 cm x 8.5 cm
- 7 years warranty
- Input Voltage
- AC 100-240 V
- Frequency Required
- 50 - 60 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 550 Watt
- Output Current
- Efficiency
- 90% (115VAC) / 92% (220-240VAC)
- 80 PLUS Gold
- Cables Included
- Power cable - external - 1.5 m , Power 24 pin ATX modular cable 60 cm , Power 8 pin EPS12V modular cable 70 cm , 2 x PCI Express power cable , 3 x power 15 pin SATA to 4 pin cable , Floppy adapter , Power cable
- MTBF
- 100,000 hour(s)
- Cooling System
- 140 mm fan
- Over current protection, over voltage protection, SLI ready, CrossFire ready, undervoltage protection, short-circuit protection, single 12V rail, dual ball bearing cooling fan, ECO Intelligent Thermal Control System, Eco-Mode, fully modular
- BSMI, CB, FCC, RoHS, WEEE, cTUVus, ErP 2013, RCM
- Limited warranty - parts and labour - 7 years
- 0 °C
- 50 °C
- 15 cm
- 16.5 cm
- 8.5 cm
- 2.72 kg
