EVGA GeForce GTX 1080 SC GAMING ACX 3.0
•1708MHz Base Clock
•1847MHz Boost Clock
•273.2GT/s Texture Fill Rate
•8192MB GDDR5X Memory
•10000MHz Memory Clock
•320GB/s Memory Bandwidth
The EVGA GeForce GTX 1080 featuring EVGA ACX 3.0 cooling has arrived. This new graphics card features NVIDIA's new "Pascal" graphics processor which is the most advanced gaming GPU ever created. This breakthrough GPU delivers industry-leading performance, innovative new gaming technologies, and immersive, next-gen VR.
- EVGA GeForce GTX 1080 SC GAMING ACX 3.0 - graphics card - GF GTX 1080 - 8 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 1080
- Memory
- 8 GB GDDR5X
- Core Clock
- 1708 MHz
- Boost Clock
- 1847 MHz
- CUDA Cores
- 2560
- Effective Memory Clock
- 10 GHz
- Memory Interface
- 256-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 4
- DVI-D , 3 x DisplayPort , HDMI
- API Supported
- DirectX 12, OpenGL 4.5, Vulkan
- 26.67 cm x 11.176 cm
- 3-year warranty
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1708 MHz
- Boost Clock
- 1847 MHz
- CUDA Cores
- 2560
- VR Ready
- Max Resolution
- 7680 x 4320 at 240 Hz
- 4
- API Supported
- LED indicator, Nvidia SLI ready, eVGA Active Cooling Xtreme (ACX), NVIDIA G-Sync ready, NVIDIA GameStream, Straight heatpipes (SHP), EVGA Backplate, Nvidia GeForce GTX VR Ready, NVIDIA GPU Boost 3.0
- Size
- 8 GB
- Technology
- GDDR5X SDRAM
- Effective Clock Speed
- 10 GHz
- Bus Width
- 256-bit
- Bandwidth
- 320 GBps
- OS Required
- Microsoft Windows 7 / 8 / 10, Microsoft Windows 7 / 8 / 10 (64 bits)
- Required Power Supply
- 500 W
- Additional Requirements
- 8 pin PCI Express power connector
- 180 Watt
- 26.67 cm
- 11.176 cm
- Limited warranty - 3 years
