EVGA NVIDIA GeForce GTX 1080 8GB GDDR5X PCIe3.0 Graphics Card
Quicklinx: C447WS00 Mfr#: 08G-P4-6180-KR
EVGA GeForce GTX 1080 - Founders Edition
The EVGA NVIDIA GeForce GTX 1080 is a quantum leap in performance. Faster than both the GeForce GTX 980 Ti and GeForce GTX TITAN X, With the power of the NVIDIA Pascal architecture, the efficiency and performance of the 16nm FinFET GPU, the blistering speed of the GDDR5X VRAM, and the craftsmanship of the fan, vapor chamber, and backplate the EVGA GTX 1080 is the world's fastest and most advanced graphics card.
The EVGA GTX 1080 uses the power of Pascal. NVIDIA Pascal is the world’s most advanced GPU architecture delivering truly game-changing performance, innovative technologies, and immersive, next-gen VR. With brilliant gameplay with captivating sights and sounds, it’s a whole new way to game.It features NVIDIA GameWorks technologies for smooth gameplay and cinematic experiences, as well as revolutionary 360-degree image capture-even in VR.
Under the hood, the new Pascal architecture is loaded with technologies that will make your games and experiences better, faster, and more beautiful. Previous-generation architectures have brought advances such as DSR, G-SYNC and HairWorks to life, and with Pascal we're introducing gamers to Ansel, Simultaneous Multi-Projection, VRWorks Audio, VR PhysX, and VR Touch.
EVGA’s GTX 1080 is a quantum leap forward in performance and power efficiency. It is built using ultra-fast FinFET, this new, smaller chip design uses fewer Watts of power and emits less heat, enabling us to crank up the core clock speed of the GPU, which is key for increasing a graphics card's performance. Alongside the FinFET is 8GB of GDDR5X memory, a new, faster type of video card memory. This cutting-edge and blazing fast, High Bandwidth memory ensures performance won’t be bottlenecked by memory-related operations in the most demanding games.
The EVGA GeForce GTX 1080 is meticulously crafted to offer superior heat dissipation using an advanced vapor chamber and premium materials, so it runs as cool as it looks. Surrounding the GeForce GTX 1080's powerful hardware is a redesigned vapor chamber and fan for cool, quiet operation; a polygonal shroud, and a backplate for the dissipation of heat from the rear of the graphics card. This premium design enables excellent overclocking and whisper-quiet operation, a trend we began with previous-generation NVIDIA GeForce GTX GPUs.
The next generation of EVGA PrecisionX utility has arrived with EVGA PrecisionX OC. This new version is built for the NVIDIA Pascal architecture and combines the best of EVGA Precision and EVGA OC Scanner to give you never before seen overclocking features and built in automatic overclock tuning. Put the power of the NVIDIA Pascal architecture in your hands with EVGA PrecisionX OC.
HDMI 2.0b / 3x DisplayPort 1.4 / Dual-Link DVI
  • Performance
    The GeForce GTX 1080 is a quantum leap in performance and power efficiency. It's built using ultra-fast FinFET and high-bandwidth GDDR5X technologies, and supports DirectX 12 features for the fastest, smoothest, most power-efficient gaming experiences.
  • Next-gen gaming technologies
    GeForce GTX 1080 uses the power of Pascal to meet the demands of the latest displays, including VR, ultra-high-resolution, and multiple monitors. It features NVIDIA GameWorks technologies for smooth gameplay and cinematic experiences, as well as revolutionary 360-degree image capture - even in VR.
  • VR ready
    Discover next-generation VR performance, the lowest latency, and plug-and-play compatibility with leading headsets - driven by NVIDIA VRWorks technologies. VR audio, physics, and haptics let you hear and feel every moment.
  • Groundbreaking design
    The GeForce GTX 1080 is meticulously crafted to offer superior heat dissipation using an advanced vapor chamber and premium materials, so it runs as cool as it looks.
EVGA GeForce GTX 1080 - Founders Edition - graphics card - GF GTX 1080 - 8 GB
Graphics card
Bus Type
PCI Express 3.0
Graphics Engine
8 GB GDDR5X
Core Clock
1607 MHz
Boost Clock
1733 MHz
CUDA Cores
2560
Effective Memory Clock
10 GHz
Memory Interface
256-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
DVI-D , 3 x DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5, Vulkan
26.67 cm x 11.176 cm
3-year warranty
Graphics card
Bus Type
PCI Express 3.0
Graphics Engine
Core Clock
1607 MHz
Boost Clock
1733 MHz
CUDA Cores
2560
VR Ready
Max Resolution
7680 x 4320 at 240 Hz
4
API Supported
LED indicator, Nvidia SLI ready, NVIDIA G-Sync ready, NVIDIA GameStream, Nvidia GeForce GTX VR Ready, NVIDIA GPU Boost 3.0
Size
8 GB
GDDR5X SDRAM
Effective Clock Speed
10 GHz
Bus Width
256-bit
Bandwidth
320 GBps
Microsoft Windows Vista / 7 / 8 / 10
Required Power Supply
500 W
Additional Requirements
8 pin PCI Express power connector
26.67 cm
11.176 cm
Limited warranty - 3 years
