EVGA NVIDIA GeForce GTX 1080 8GB FTW GAMING ACX 3.0
Quicklinx: C4KGWS00 Mfr#: 08G-P4-6286-KR
EVGA GeForce GTX 1080 FTW GAMING ACX 3.0
The EVGA GeForce GTX 1080 featuring EVGA ACX 3.0 cooling has arrived. This new graphics card features NVIDIA's new "Pascal" graphics processor which is the most advanced gaming GPU ever created. This breakthrough GPU delivers industry-leading performance, innovative new gaming technologies, and immersive, next-gen VR.
  • Performance
    The GeForce GTX 1080 is a quantum leap in performance and power efficiency. It's built using ultra-fast FinFET and high-bandwidth GDDR5X technologies, and supports DirectX 12 features for the fastest, smoothest, most power-efficient gaming experiences.
  • Next-gen gaming technologies
    GeForce GTX 1080 uses the power of Pascal to meet the demands of the latest displays, including VR, ultra-high-resolution, and multiple monitors. It features NVIDIA GameWorks technologies for smooth gameplay and cinematic experiences, as well as revolutionary 360-degree image capture - even in VR.
  • VR ready
    Discover next-generation VR performance, the lowest latency, and plug-and-play compatibility with leading headsets - driven by NVIDIA VRWorks technologies. VR audio, physics, and haptics let you hear and feel every moment.
  • Groundbreaking design
    The GeForce GTX 1080 is meticulously crafted to offer superior heat dissipation using an advanced vapor chamber and premium materials, so it runs as cool as it looks.
EVGA GeForce GTX 1080 - FTW Edition - graphics card - GF GTX 1080 - 8 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
8 GB GDDR5X
CUDA Cores
2560
Effective Memory Clock
10 GHz
Memory Interface
256-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
DVI-D , 3 x DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5, Vulkan
26.67 cm x 15.088 cm
3-year warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
CUDA Cores
2560
VR Ready
Max Resolution
7680 x 4320 at 240 Hz
4
API Supported
LED indicator, Nvidia SLI ready, eVGA Active Cooling Xtreme (ACX), NVIDIA G-Sync ready, NVIDIA GameStream, Nvidia GeForce GTX VR Ready, NVIDIA GPU Boost 3.0
Size
8 GB
GDDR5X SDRAM
Effective Clock Speed
10 GHz
Bus Width
256-bit
Bandwidth
320 GBps
Microsoft Windows 7 / 8 / 10, Microsoft Windows 7 / 8 / 10 (64 bits)
Required Power Supply
500 W
Additional Requirements
2 x 8 pin PCI Express power connector
26.67 cm
15.088 cm
Limited warranty - 3 years
